Box blade size
/ Box blade size #1
tld
Boston, GA
JD 2025r
What is the best size box blade for a CUT that has back wheel width? I have looked at the 48 in and the 60 in. The 60 looks really heavy for the 25 hp JD 2025r.
/ Box blade size #2
You can also get a 54" width in several brands, I have a Cammond for my mower and like it. While I chose the 48 for the smaller machine a 54" would work for the 2025R.
/ Box blade size #3
I have a 72" and 48". I find the 48" almost useless. I use the 72" for grading one my gravel drives and a little earth work. The 48" sits idle. I use my jd 2320, the 2305 never sees bb work.
/ Box blade size #4
For sure, you want the box to be no narrower than the rear wheel tire tracks (not the sidewalk, the tread where it leaves a mark on the ground). Some like it a bit wider, but I have always preferred it to be just a few inches wider myself. I had a 50" box for my Kubota B2920, and have a 60" on my L3200.
/ Box blade size #5
I used a 60 inch box blade with a JD 790 and it handled it well when I bought a Kubota L3700 stepped up to a 72 inch box blade Good Luck
/ Box blade size #6
When in doubt, a good rule of thumb is to get the width of your loader bucket. Many prefer to have it a few inches wider than the bucket.;)
1100 GAL PLASTIC STORAGE CONTAINER (A63745)
1100 GAL PLASTIC...
30" X 144" STAINLESS STEEL TABLE (A63745)
30" X 144"...
(INOP) INTERNATIONAL EAGLE DAY CAB ROAD TRACTOR (A63745)
(INOP)...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
