Box Scraper vs. Land Plane/Grader Scraper
   / Box Scraper vs. Land Plane/Grader Scraper #11
Here is a link to a post I started..........as you can see in my last post I purchased a Durabilt DP60 and pull it behind a Ford 4000 1973 3 cylinder diesel. Have put at least 220 hours pulling this thing. Here lately I have had a longer haul and have been stockpiling loose dirt dug with dozer or full size backhoe and then using the front loader to fill the scoop to overflowing heaped up to get the most out of the mileage for each lap on the haul route............ http://www.tractorbynet.com/forums/attachments/193531-dirt-pan-3.html
   / Box Scraper vs. Land Plane/Grader Scraper #12
I have a Bush Hog RO72 roll-over box blade and a Land Pride GS2584 grading scraper. I've never needed to use the roll-over box blade(ROBB) on my mile long gravel driveway. I use the grading scraper on the driveway and I create new trails throughout the property with it also. I use the ROBB when I need to move dirt/gravel on a newly created trail. I also have a hydraulic top link which is FANTASTIC. It allows infinite adjustment of an implement while on the go.
IMHO you need to get a grading scraper to maintain the driveway and then obtain or make an added weight to use on your existing box blade. I made a form and poured a concrete weight - 400 lbs - that I can place on top of my "dirt work" implements. It fits on my ROBB, LPGS, disk harrow and rear blade. This weight is mainly used(99% of the time) on my disk harrow.
   / Box Scraper vs. Land Plane/Grader Scraper #13
Both have there purposes depending on use but I agree that weight is your friend.
   / Box Scraper vs. Land Plane/Grader Scraper #14
I have used a box blade for years and they have their disadvantages. If you have a FEL I prefer that to a box because the tractor tires are behind the blade on a smoother surface. Still, with either, it's hard to control the depth of the material that you are trying to spread.
I have seen a professional build a driveway with a "land plane" like the $1000 King Kutter 84" Dual Edge Land Grader that shows up on the right when you google search for "land plane". They work fast and really do a super job in leveling new material (like the piles of crushed rock that you bring in) or cleaning up potholes. Would buy one in a heartbeat to maintain a gravel drive. On a dirt road, if the dirt is of the type that it can be pulverized as it is scraped up and retained in the hopper then that should be fine also. If not, you may have to make several passes and between passes, let the clods that form get rained on and pulverize then come back again and it should work for you.
Mark
   / Box Scraper vs. Land Plane/Grader Scraper #15
Howdy folks,
I have a large dirt parking lot and 3/4 mile of dirt road to maintain. Not to mention horse paddocks, etc to keep clean. In terms of total time, I probably have a little more road/parking lot related chores, but it's really close to an even split. In the coming year, I'll probably have to renovate one or more large horse riding arenas (moving the existing footing, putting in a base, spreading/leveling it and then putting the footing back). I'm trying to decide between getting a box scraper (I like the looks of the Woods BSM72) or a land plane (something similar to a Landpride GS1572). In a perfect world, I'd get both, but I can only afford one for now. Any opinions or feedback would be appreciated. BTW, I have a 2008 JD 4520 w/CX 400 loader.
Try the ABI Attachments LGR and you can have both. Here is a link Rascal LGR™ - Affordable Driveway & Arena Groomer - ABI Attachments
Does great on my property.
   / Box Scraper vs. Land Plane/Grader Scraper #16
If you have a 4520 I would suggest a 84" implement being either a box blade or grading scraper . I have a 84 " cammond industrial grading scraper with teeth that weighs in at 930 pounds, and a landpride 84" hydraulic box blade that weighs about 1200 pounds . I use the grading scraper about 80% more than the box blade. I use it to maintain about 2 miles of gravel roads in a campgound as well as a couple parking areas. I had a 72 inch 650 pound box blade and I felt it wasn't enough for that size tractor. Cammond is now called superior fab and I feel they made a quality product for a reasonable price
   / Box Scraper vs. Land Plane/Grader Scraper #17
I live off a 3 mile Gravel Road. Whenever the folks used a straight blade to grade the road, we would have pot holes starting within days after a rain.
As soon as they started using a grader machine that applied a crown to the middle of the road we go a full year between grades, compared to three - four times per year.
Won't the box blade remove the crown in the middle of the road?
   / Box Scraper vs. Land Plane/Grader Scraper #18
ANY blade will if you run it flat, down the middle. So don't do that. :)
Bruce
   / Box Scraper vs. Land Plane/Grader Scraper #19
Crank your side links (or hydraulic tilt) and a box or back blade can put on a crown. I bet a heavy back blade would be slightly better than a box for that, but not by a huge amount.
   / Box Scraper vs. Land Plane/Grader Scraper #20
You don't do this with a box blade.
First picture is ditching and adding to the crown of our shared road.
Second & third pictures are actually moving a road over about 4' that is located higher up on our property.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
*Selling at Royal Auction Tampa, FL Location* 9, gooseneck hitch, (A59230)
*Selling at Royal...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
1762 (A58375)
1762 (A58375)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
