Bradco boom dropping way to fast.
   / Bradco boom dropping way to fast. #1
simmysam3
Spokane, WA
TYM 330 HST
I have a bradco 3265 attached to my TYM 330HST.
It supplies plenty of power to each of the cylinders - no issue there. However when dropping the boom it just releases - and drops almost uncontrollably. I try to manage it but it leaves me with an incremental jerky motion as I lower it at best. If I drop it super slow, barely touching the stick it will drop very gradually - far too slow to be practical. The problem is there is no "in between" where I can actually control a reasonable rate of drop.
I have run it at various RPM's, adjusted the flow control in and out, but all to no avail.
Any thoughts?
Sam
   / Bradco boom dropping way to fast. #2
did this used to operate smoothly?
   / Bradco boom dropping way to fast. #3
Sounds like the spool valve is faulty
I don't think it ever was smooth. Perhaps a "little" better than it is now.
If the spool valve is faulty, does that generally involve replacing an entire assembly, or would it be replaceable seals?
Thanks,
Sam
   / Bradco boom dropping way to fast. #5
Thanks,
Sam
You should be able to rebuild it. I have a Bradco 611 and the controls are very smooth every direction.
   / Bradco boom dropping way to fast. #6
There really is nothing in the valve to rebuild.
I am wondering if this valve has load checks?
   / Bradco boom dropping way to fast. #7
Has a hose or fitting been replaced? Might have had an orfice to slow it down.
   / Bradco boom dropping way to fast. #8
Okay, reassemble it. The spools can stick, there are o-rings that may not be sealing, etc. (particularly the one sealing the hyd fluid when dropping the boom). Spool valves do have issues from time to time, particularly if the fluid was/is contaminated. But you are right, try everything else first. Swap spools and see if the problem follows that spool. ie move dipper and boom spools (spool valve in the assembly) and see if the problem moves.
   / Bradco boom dropping way to fast. #9
Any oring that is in the valve, if not sealing, would cause a puddle of oil.
Passages in the valve are NOT sealed off from one another with o-rings. The only o-rings are to seal the spool to the casting so oil don't come out where spool protrudes for the handle to connect, and for the spring/detent me under the can
   / Bradco boom dropping way to fast. #10
Try turning the spool 180 degs. Take the can off the bottom of spool and make sure everything is right there.
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
JCB 3C 15' BACKHOE (A60429)
JCB 3C 15' BACKHOE...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
