Brake Drain Plug
/ Brake Drain Plug #11
Glad you got it done JohnJ
Did you replace the 2 seals & O-ring I posted in reply # 4 ?
Were the friction plates OK ?
Did you lose all the fluid when you removed 1st outside brake housing or when you removed seal ?
Thanks, David
/ Brake Drain Plug #12
Did seal replace right side Sunday, took me about 5/6 hours (lt was hot)
Went pretty good until l saw that l had forgotten the lock ring, lucky l saw it before l had put everything back together
The only regret is l did not have new gaskets, so l made new ones
The friction plates looked like new & were just a little oil stained on the bottom,
David
/ Brake Drain Plug
Great. I'm glad you got it done. My brakes work really well now. Still, last evening I cut my 354 down from a tree (the story of stupid I guess) and need to assess any damage now. I know I have a crumpled fender and a flat tire for sure, hopefully not much else.
JohnJ
/ Brake Drain Plug #15
JohnJ
I have to hear this story.
Did it start with "hold my beer and watch this"?
Chris
/ Brake Drain Plug #16
I am quite interested in hearing the story as well. You certainly have my attention so far!
/ Brake Drain Plug
Turns out it's really not difficult to tree a tractor. Here's a quick instruction, if anyone would like to try.
I was cutting down a steep hill (50 degree or so) thru 6' tall brush, mostly briars, heading down a track between a some trees. The path took me down the hill at two angles, the downhill slope and a 15 to 20 degree slope to the right. Just as I got to the bottom of my planned run and was ready to turn out after passing a final tree on my right, the ground turned to rubble. Someone has dozed up a bunch of stumps and such, now hidden by brush and briars. The tractor was on top to the rubble with a large pile directly underneath, raising the left rear wheel (the high side) off the ground slightly. And there was a distinct teeter-tottering going on as my left front tire suddenly went flat. I thought it best to cut my losses and try to turn out to the right which was now on an even greater rightward slant. The turn was slightly before the plan so that last tree on the right (a 7 inch mimosa) was being smashed down by the right rear tire as I began the turn. I figured this would have to work, since I saw few other options. Well as the tree bent down one of its branches hung between the hood and the right side of the FEL, which made the tree base pull more to its left, causing the base to become wedged between the right rear wheel and the fender. To make matters worse, another limb grabbed the FEL joy stick and pinned it back, raising the bucket to its fullest height, while the tractor was still halfway into the turn on the slope. A bit of puckering going on now. Fortunately the tree keep the tractor mostly upright.
In the end, I had to saw the tree down. First the limbs holding the joy stick (so I could lower the bucket), then the tree trunk which had the tractor treed. Of course I had to remove the bush hog which was uphill of the tractor and sitting on the afore mentioned rubble. I also had to remove the right lift arm so I could get in with a bow saw to cut the base down. So the end result, the flat tire will likely need a new tube, the right fender will need to be broken away from the tire, the right rear wheel has two small curls in the metal near the tire bead, the joy stick is bent slightly, and the FEL is a bit more sluggish then it was before (still need to assess that more, as well as the hog which is still on the hillside).
All's well that ends well.....just wish it would end :)
/ Brake Drain Plug #18
Well, Well, JohnJ, Glad you didn't get hurt, Hope Tractor is OK,
Although you had a worse wreck than me, (Steering Wheel Thread)
I hung up on a large unseen stump in a 8'/9' high briar patch & had to get the 304 sideways to get off, a little hairy, as I thought it might turn over
Looks like your damage is fixable
Be sure to check under carriage, I broke the welds off the clutch/brake rod & 3 or 4 grease fittings
David
/ Brake Drain Plug
Thanks for the advice. I've stranded it on a log before as well. For that one I was able to put another log under the FEL and push down enough to pull the first one out. I've got to get this brush under control enough to see all the stumps, logs, and holes.
/ Brake Drain Plug
Anyone have a source where I can buy 7.5x16 lug tires?
MAGNUM LIGHT TOWER (A60736)
MAGNUM LIGHT TOWER...
2012 MACK GRANITE DAY CAB (A60736)
2012 MACK GRANITE...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
