Brand new L2501 started making a nasty noise at 6 hours
/ Brand new L2501 started making a nasty noise at 6 hours #41
Sounds like a 98 Chevy truck I had, ended up being bad lifters. Sorry to hear about your L2501 problem. Hope it gets repaired fast.
/ Brand new L2501 started making a nasty noise at 6 hours #42
1st sorry to hear your new tractor is knocking.
My guess would be a spun rod bearing,
and the increased clearance on the rod journal is allowing a piston to actually strike the head.
Would have guessed a stuck injector- But the engine (sounds) like all cylinders are firing normally. Hard to tell listening to a recording Also because of no exhaust smoke.
A pic of the oil on a white rag or in the bottom of black bucket would help determine if there is actually bearing Babbitt in the oil. Grey oil doesn't sound normal.
Here's Hoping it is just a bad injector or bad lifter (assuming Hydraulic)
or rocker clearance adjuster backed off/came loose -and the oil is not full of bearing material.
Hope the dealer get's it fixed quick and correctly for you.
/ Brand new L2501 started making a nasty noise at 6 hours #43
I’ve had air in the injectors before and that didn’t happen. I’m guessing the cylinder is hitting the head. I agree with don’t worry about it and let the dealer take care of it.
The plot thickens and we were all wrong.
There was some kind of metal FOD in one of the cylinders. It trashed the cylinder, head, valves, and piston.
Waiting on pictures now, Kubota is apparently sending someone up to investigate.
Also, they've already approved a new engine, so the shop is waiting on that.
/ Brand new L2501 started making a nasty noise at 6 hours #45
Glad you got it figured out.
I'm looking forward to seeing the pic and if it's a piece of one of the rings or something else. If it's something else, what on earth is it and why was it in the engine? The dealer said it looked like a piece of welding rod.
/ Brand new L2501 started making a nasty noise at 6 hours #47
Sad, but now you know! S*^t Happens. Glad you got your answers and the replacement is happening.
/ Brand new L2501 started making a nasty noise at 6 hours #48
I've heard stories on some products where a bit of something left over from the manufacturing process wasn't cleaned out. Maybe a milling shaving? Burr from a stamping?
/ Brand new L2501 started making a nasty noise at 6 hours #49
Details are certainly an interesting topic to discuss. This can happen to any blue, orange, red, or green equipment. $h!t happens.
MAIN thing is our fellow TBN member is getting his new engine and while mfr has someone coming to look at the defect, hasn't held up the fix. :thumbsup:
/ Brand new L2501 started making a nasty noise at 6 hours #50
I want to congratulate you on having a dealer who can pick up your tractor late morning one day and by first light the next day have removed the head, discovered the problem and have a new engine on order. !!! Post their name and give them some well-deserved recognition.
/ Brand new L2501 started making a nasty noise at 6 hours #51
Wow - foreign metal in a cylinder on a new tractor that ran perfect for 6 hours??
Pictures would be interesting for sure. Would like to see the Valve and Seat faces to see if it really came thru the intake port. Is the piston crown still fully intact?? Yes the plot did thicken
Glad to hear Kubota is sending a NEW engine.
/ Brand new L2501 started making a nasty noise at 6 hours #52
I have a feeling they were as curious as any of us. My LS dealer did more or less the same thing with my traction issue, but of course they didn't have to do that much disassembly.
/ Brand new L2501 started making a nasty noise at 6 hours #53
Very true. Any/all Kubota dealers SHOULD do exactly that, go to battle stations immediately when a brand new tractor with only 6 hours has an infant mortality of some sort. Hard to say how many really would. Good idea to publicize the excellent response. I have no question that Kubota will make all that right.
Looking like a piece of welding rod is wild/alarming of course. Maybe it is a piece of a piston ring, maybe a fragment of casting debris, maybe a chunk of the piston itself, maybe something left loose in the intake area and sucked in during running? Be very interesting to find out. One strange thing is that most mfrs run up the engines and do at least a quick running test on it before in goes into a finished tractor. Wonder why it did not show up then? That's why I'd lean slightly toward a speculative guess at something being sucked in via the intake a little later in the sequence.
p.s. : Having trashed so many things -- piston, head, etc. it may be nearly impossible to figure out what came first and what was a subsequent victim.
/ Brand new L2501 started making a nasty noise at 6 hours #54
It was probably how the OP handled the situation.
In any event, interesting scenario. -- It can happen!
/ Brand new L2501 started making a nasty noise at 6 hours #55
I had a liner break loose and about 1/4 of the liner ended up getting smashed by the piston into the head. Sounded just like your engine did. Kubotas do not have liners so that is not it but the effect is the same. My head magnafuxed fine so I dodged a bullet. Glad to hear they are giving you a new engine.
/ Brand new L2501 started making a nasty noise at 6 hours #56
I thought that rap was too sharp to be a bearing. Had something similar happen on a prototype engine. It ran fine for about 36 hours and then had a similar sharp rap noise. When we tore the head off we found the head had broke off a valve. As it was built as a prototype and not production, it was more prone to mistakes. The timing gears were assembled 1 tooth off. New computer controlled timing compensated so it made full power but valves being slammed by pistons couldn’t take the beating and one head broke off causing a similar noise.
/ Brand new L2501 started making a nasty noise at 6 hours #57
Arcli9ht, didn't you post prior to purchase about your dealer dragging their feet on the sale, you couldn't pick it up without a tow vehicle upgrade, and had a bunch of concerns about the dealer? Didn't someone say the implements delaying the sale was "service" and that spoke volumes?
Well, unless I'm confusing you with someone else, I'd say after all the concerns, your dealer certainly stepped up to the plate. And some say "I've never had to take mine back to the dealer in 2,500 hours". Imagine the extra hassles if you had purchased from another dealer. Glad you have a winner there. Good luck and hope to hear you working that rig again real soon.
/ Brand new L2501 started making a nasty noise at 6 hours #58
I listened to the post again.. yes, the that is exactly what I heard in my situation. I shut mine down immediately. Very nice to see Kubota atepping up so fast. Shlt happens in the factory, there is always the potential of something like this happening.
My jaw dropped when I saw these. It's amazing how much damage something the size of a fence staple can do. Also amazing how little clearance is in these engines, they're real marvels.
It's definitely not part of the cylinder, piston or liner.
With that huge hump in the air intake, I have a hard time believing this wasn't in the head or in the cylinder from where it was manufactured. Poor kid never had a chance.
I did, and it is. I'd move their name from that thread to this if editing was allowed.
Shame after all that time the tractor was a dud, but they had it picked up the first business day after I emailed them on Sunday and torn apart that same day.
2013 Nissan Rouge SUV (A59231)
2013 Nissan Rouge...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
208315 (A58376)
208315 (A58376)
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
UNUSED FUTURE 16" HD MINI EXCAVATOR AUGER (A60432)
UNUSED FUTURE 16"...
JOHN DEERE 26G EXCAVATOR (A60429)
JOHN DEERE 26G...
