Bridge possibilities
   / Bridge possibilities #21
Those old fuel tanks should work really well for polluting all the water and soil down stream. Including peoples well water.
   / Bridge possibilities #22
One possibility, if the normal stream flow is very low, is to pave/gravel (with big gravel) a low area that actually dips down into the stream. Just use some small culverts or plastic pipes to carry the normal flow and let it overflow when a gully washer comes along. If it's low and sturdy enough, it may not wash out but would be easy to fix if a little does. This is the route I went in building a crossing over a little spring/pond-overlfow-fed stream beside my property. It hasn't suffered an overflow yet to test it out. It's only 7' wide. My tractor is only 4' wide. Used concrete bags along the sides above the PVC pipes. Just cut away the bag material at the top and wet them to solidify.
Ralph
   / Bridge possibilities #23
That reminds me. /forums/images/graemlins/blush.gif
A home builder has an eight by twenty gas tank he spent eight hours cutting off one end.
After that he came to me to cut off the other end and then split it down the middle both sides.
He's wanting to make two driveway culverts out of the material.
I quoted him three hundred to do the cuts. I don't know what he paid for the tank.
It might be a long day after all. /forums/images/graemlins/frown.gif
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
2023 Deere 325G (A60462)
2023 Deere 325G...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
