Bridge possibilities
   / Bridge possibilities #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I am still looking at making a creek crossing for my tractor (posted here a few months ago). Creek bed is about 4 feet deep and 8-10 feet wide (mostly from erosion). Previous owner had a 42 inch galvanized pipe culvert which got washed out. I would reinstall it but it is only 9 feet long and would not be wide enough for a tractor crossing.
I was thinking of making a bridge instead but don't want to pour concrete footings for various reasons. Does anyone have any thoughts about buying an old flatbed trailer (say 35 feet long), cutting the wheel assembly off and laying it across the creek? With such a long bridge over such a short crossing I was thinking I wouldn't have to pour any footings.
By the way, I did price out plastic culvert pipe from local suppliers. A 20 foot piece of 42 inch HDPE would cost me close to $1,000. There is a local salvage yard selling a 1965 35' Freuhauf single axle flat bed trailer for $1,250. I have also heard of using an old flatbed railcar (from a post here I think) but they cost more than I want to spend.
   / Bridge possibilities #2
could you post a picture of the bridge area please? I think I remember your post from before but not too sure. Were you the guy that was going to use cedar trees to make a bridge?
That wasn't me. I'll try to get some pictures this weekend when I am there.
   / Bridge possibilities #4
Oops! Sorry for the mix-up. Pictures will help a great deal.
   / Bridge possibilities #5
I helped a friend do that about about 20 years ago. I had the torch, they had everything else. I think it may have been a 30+'er but maybe shorter. It was an older trailer that had the frame fishplated (strongbacked). Their stream was a youngster so it was not too wide but steep sides and carried a lot of fast water. They tried to position it by pulling with a tractor and pushing with house moving jacks but couldn't get it. They finally asked the neighbor with a small (D2-3) Cat to push it into place. Worked out great!
Cheers!
   / Bridge possibilities #6
Bridges are almost always better than pipes from the fishy point of view. Even the flatbed trailers have weight ratings. I would try to research whether that trailer was built to be loaded heavy or to load something very light before buying it.
The farther the bridge extends onto the land on either side, the less likely you are to need any kind of footing.
   / Bridge possibilities #7
I think the trailer is a good idea. That is what I am planning, except that I am planning on some concrete footers. My creek is more like 15'-20' wide and 10' deep. And it does occasionally flood. I don't want all that water pushing against the trailer once I get it set in place so I plan to raise it a little above grade. If you don't have that much flow, then probably not a problem for you. I have located a 40' trailer and am working to get possession of it. Then I will have to figure the logistics of getting it to my place and then set across the creek.
   / Bridge possibilities #8
RobA,
I have two 48" x 16' galvanized culverts for my driveway crossing and I don't remember them costing near that much. But that was seven years ago and steel wasn't near the price that it brings now. After going through the possibilities for bridge designs, my father and I both decided that the culverts were the best alternative for me. We reinforced the ends with cinder blocks poured full of concrete and steel rods driven into the creek bed and they are still there today and have given excellent service.
Jeff
   / Bridge possibilities #9
Along HI 80 ( or is that 40) going up to Echo SUmmit towards Lake Tahoe, you will find several flat bed rail cars used for bridges traversing some of the many streams in the area.
No footers were typically used but conctrete or asphalt was used at the beginning and end of the trailer/bridge/rail car.
   / Bridge possibilities #10
If the crossing is only 10' wide, you have very good options for bridge design. There's a huge difference in a 10' bridge and (for example) a 20' bridge. A 10' long bridge doesn't have to be real beefy to support a 10,000 pound tractor with perfect safety. You could even build it to support 30,000 pounds for a huge safety factor, and it would still not need to be real beefy. You won't need any fancy footings either. Just something wide enough to prevent the beams from sinking into the soil.
I would build it from 4 10' I beams of sufficient size, probably 1 footers lightly latticed, with a few diagonals to triangulate. Deck could be treated (dimension) 2x6, 2x8, etc. Footings could be cross ties. In fact, the whold bridge could be made from treated dimension 2x lumber, with 4 big laminated beams replacing the I beams.
You can have fun with a 10 footer. Just build it 2x or 3x stronger than needed, and you can't go wrong. If it needs to be longer than 10', all bets are off! /forums/images/graemlins/smile.gif
Whatever you decide to build it from or use, high water is a far bigger concern than strength. If the water comes up pretty high, say 5-6' depth and swift, you will need to anchor the bridge down real good. That isn't hard to do either for a 10 footer. If the water gets very swift and/or comes up say 8', your options quickly vanish. Big rushing water is a monster, and will defeat you if you take it on head-to-head.
   / Bridge possibilities #11
Another source of less expensive materials might be military surplus. I can't remember where I last saw this, but I've seen ads for sales or disposition centers where portable bridges and other big stuff usable as a bridge can be bought. Maybe someone else in here can help with more specifics.
   / Bridge possibilities #12
Heres what I did with almost the same size creek. I was considering a trailer but nothing came in the price range, looked at the railroad car thing but it was to expensive to transport. I also did not want to spend the money on new lumber for that particular project.
I was driving down the road one day next to the railroad tracks and they were replacing track and had a giant pile of used ties laying next to the track. I mentioned it to a friend and he saw some inspectors going along the track and asked what they were going to do with them and they said "givem to you" /forums/images/graemlins/grin.gif I found about 15 in really good shape so I took those. They must weigh around 300lbs apiece, everything me and a friend could do to lift them on the trailer.
I kept it simple, dug down about 6" to 8" with the loader on both sides of the creek and set them in and filled in the exposed ends. Works like a champ /forums/images/graemlins/cool.gif
The longest one is 13' and shortest was 12'. Good Luck.......
   / Bridge possibilities #13
Another a little closer.....
   / Bridge possibilities #14
Here is my foot bridge being used by one of my dogs poker buddies, cought him leaving early this morning after an all-nighter /forums/images/graemlins/grin.gif
   / Bridge possibilities #15
Do a search for "ATV bridge" in "projects".
Then plan a TBN party.
Here is a picture of the washed out pipe. The weeds are getting overgrown and hide the creek bank. We haven't had a lot of rain lately so the flow is real low. The creek always flows but is not heavy unless we have a lot of rain. Even then I think the 42 inch pipe in the creek is not too small - just installed incorrectly.
More pictures to follow.
Here is another picture of the pipe looking downstream. The tree in the creek was left by the guy who timbered the property. As soon as I can get across the creek easily I'll grab it with the grapple and get it out of there.
This is a picture of the creek 50 feet upstream of the washed out pipe. The creek bends left and then right to where the pipe is.
   / Bridge possibilities #19
Will that pipe handle the spring snow melt run off and heavy rain from the storms if it were installed properly? That is the point to ponder but with a trailer bridge you would not have to worry about entreme high water wash out. The pipe of proper size and install corectly many work very well for many years but the ther is always the chance of that one time when it doesn't.
   / Bridge possibilities #20
I had a "bridge" made of 4 parellel concrete culverts, oval cross section, 19in X 30 in wide. They could hand the peak flow ok but they all washed out when debris from a gully washer plugged them . I could see that happening with the culvert you had as well.
An local excavating contractor was going to bridge this same creek on his property. He had some underground tanks he salvaged from gas stations probably. He was going to cut the ends off and use them as giant culverts. They would be big enough that plugging would be unlikely.
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
CAT 336E (A58214)
CAT 336E (A58214)
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2016 CATERPILLAR 330FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
