tderrick
wolc123 said:Close the gas valve and remove the gas line from the carb. Open the valve and see if you have flow. If you do not, then there is probably crud built up in the bottom of the tank that is blocking flow. If that is the case, you will want to remove the tank and clean it out good. Glad to hear you got the 8n back in service. I still want to know which one you like better when they are both going.
Thanks! It turned out to be the floats...
The competition is almost ready to commence... 8N vs 640
The hay is going to be flying!!
