Brush Hog or Finish
   / Brush Hog or Finish #1
makwa
Michigan
2006 B3030
Okay, I have a delema I need to fix by tomorrow afternoon.
I have to let the dealer know if I'm going to get the finish mower or the brush hog.
I know it all depends on what I am going to mow but what do all of you use most?
I have about 5 A that I want to mow but it's not yard grass. It's more like field grass.
Would the brush Hog do a well enough job to where the field would look decent and not hacked up?
This picture is the brush hog for around $ 700
I have been reading this board until I can't see anymore.
-Duane
-Duane
This is the finish mower for $ 1,700.
Not to sure if this is a good price also as I have been seeing the land prides a little cheaper.
-Duane
-Duane
   / Brush Hog or Finish #5
There is no doubt you can use a rotary cutter for "finish" mowing. I wouldn't do it right next to my house as the finish is clearly not as fine, but at a distance it will look very good if cut short enough. I have set mine at about 4 inches and used it like this. In fact, I have about 8 acres that I plan to do this with routinely as soon as I get the rocks out and get a larger tractor/cutter. Up close to the house in areas that folks pay more attention to, I use the mid-mount finish mower.
On the other hand, if the ground is rock free, reasonbly smooth, you plan to keep it mowed routinely, and don't need a rotary cutter for other uses, I would go with the finish mower. It will look better, although arguably only for the 1st day or 2 after you cut it.
BTW, what brand are the mowers you are looking at?
Terry
   / Brush Hog or Finish #6
Terry
</font><font color="blue" class="small">( There is no doubt you can use a rotary cutter for "finish" mowing. I wouldn't do it right next to my house as the finish is clearly not as fine, but at a distance it will look very good if cut short enough. I have set mine at about 4 inches and used it like this. In fact, I have about 8 acres that I plan to do this with routinely as soon as I get the rocks out and get a larger tractor/cutter. Up close to the house in areas that folks pay more attention to, I use the mid-mount finish mower.
Terry )</font>
Thanks, That's what I was leaning towards. The Brush Hog.
Not sure of the make. Thay are at the Kubota dealer and I took the pictures while the owner was inside and forgot to look and ask about the brand.
I will tomorrow though.
-Duane
Terry )</font>
-Duane
   / Brush Hog or Finish #9
Maybe too late for your decision, but I have both, and I use the finish mower 99% of the time and the rotary once a yr, if that. It really depends on what you are mowing and how often. I used the rotary a lot to get things cleaned up and manageable, and now I can mow about anywhere with the finish mower. After hay is made, I keep the fields mowed down with the finish mower.
   / Brush Hog or Finish #10
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
