Brush Hog Setup
   / Brush Hog Setup #11
All good comments, only one thing to add.
Make sure that your lower arms are "LEVEL". if not your cut will be on the angle and it will trim lower on one side and longer on the other. Looks like C*ap... don't ask how I know.
   / Brush Hog Setup #12
Before you start, make sure your blade bolts are TIGHT and the blades swing freely. I had a lot of trouble with this (shoulders too short & bind the blade), the manufacturers make shims to increase the length of the shoulder area. It makes a difference
   / Brush Hog Setup #13
I was reading the operator's manual on a Bush Hog 2010 that I was thinking of buying. It specifies that you should check the blade bolt tightness BEFORE EACH USE for 600 ft lbs.
Sorry, but I'm not going to block up a mower and crawl under it every time I use it. I'm not even sure how you measure 600 ft lbs laying on your back under a mower.
I know Bush Hog has (had) a good reputation, but if that's their operational requirements, maybe they deserve to be bankrupt.
Ken
   / Brush Hog Setup #14
Ken
Every manufacturer includes items in their operator's manuals that come from the legal department rather than the engineering department. These inclusions are easy to spot for most readers.
That said, I've not seen a Bush Hog rotary cutter built in the last 35 years that required being anywhere except above the machine to tighten the blade bolts. There is a small hole in the deck just in the right place to access the blade bolt nuts. Pretty common feature across the industry, in fact.
   / Brush Hog Setup #15
I use a 3/4 drive ratchet and the correct socket plus a 6 foot piece of pipe. I own a BROWN 472. There manual states to tighten every hour for the first 8 hours of use. So once you get the bolts tight, you can just check them every so often. If the bolts are allowed to run loose they beat out the mounting holes, then you can never keep them tight. I mow more than just fields of grass with mine so, I have found it to be to my benefit. I had a howse 500 that did not have the deck hole... I ended up destroying that mower...
   / Brush Hog Setup #16
and, if you have a ford 2n/9n/8n, you should run an over-running coupler to prevent flywheeling.
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
