rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,534
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I've been following along. After a few years of tractoring you will get more comfortable with hydraulics. All part of the tractor hobby. The nice thing about hydraulic cylinders is that they are usually simple to repair and real satisfying to go from something barely working at all to something working like new - all for not much money.
And if hydraulic repair doesn't ring your chimes = most rural towns that have a tractor dealer also have a small hydraulic repair shop. It's often a one person small shop.We've got a good one locally. They will rebuild a cylinder so reasonably its hardly worth doing it yourself.
The 512 is a nice little loader, and very popular....but it's not very heavily built. Although to be fair, even an industrial loader isn't going to stand up to pushing forward with the lip pointing down. On the plus side, if you google the JD 512 loader you will find plenty of illustrations of parts, people selling kits, & articles on parts and upgrades.
Sometimes it's a better deal to just upgrade the cylinder. Especially so if the rods are bent or the cylinder is bulged. Aftermarket cylinders are surprisingly inexpensive. You can get thicker cylinder walls & larger diameter rods & if you keep the inside areas the same or close it will work the same. I'm a fan of bushed ends, and of end caps/glands that unscrew to replace the outer dust seal and O ring. Many cylinders use universal parts. The biggest problem I've found with aftermarket cylinders is getting one that has the input and output ports pointing the right way to fit the hoses. There are common adapters for threads and bushings.
rScotty
rScotty
