BUILT A "CARRY-ALL" FOR TRACTOR
   / BUILT A "CARRY-ALL" FOR TRACTOR #22
Today I had my first try out for the "carry all"View attachment 278215View attachment 278216. It i worked perfectly along with the Kioti tractor. I know these logs weren't the biggest but the 3 point lifted it with no problem.The front end didn't seem light and there was no logs in the FEL. The best part is my welds held up to the weight. ( I'm not a welder)
Sweet...was the Patridge Family over for a visit also? :D
   / BUILT A "CARRY-ALL" FOR TRACTOR #24
I figured i would post into this threat VS making my own seeing as i took 90% of the design points from you.
I'm not finished yet but here is what i have so far. The upright 2X4's are for when i carry plywood. The last picture was before i added those and the wood kept sliding off. and yes thats gas and matches next to each other don't ask haha. just kidding i found the match book sitting somewhere and i tossed it on the carry all to bring to the shed.
   / BUILT A "CARRY-ALL" FOR TRACTOR #25
I purchased a Countryline Carry All from TSC but returned it after hooking it to my Kubota L3400. The lower 3ph attachment points were so high I could only lift it 11" off the ground which I considered unsatisfactory. I thought about cutting and re-welding but decided to return it in the end. I will build one from scratch sometime to better suit my actual needs and wants.
   / BUILT A "CARRY-ALL" FOR TRACTOR #26
View attachment 282047View attachment 282048View attachment 282049
View attachment 282050View attachment 282051
What...no gunpowder? :D
It looks great!!! I love mine. I use it for a ton of stuff. ( firewood, garbage out to road, add a couple of chairs and cooler for tours of the property etc.) I was worried about the tractor having enough power but with the box heaping with firewood ,saw, gas the thing has no problem with the load. It was a great add for the tractor.
   / BUILT A "CARRY-ALL" FOR TRACTOR #28
The last thing i want to do is add a reciver hitch to it so i can move a trailer from time to time without having to remove the carry all. The thing is i need it tucked under so the little door can still swing down.
But a hitch for me is a must. that should be the last little add item i think. but who knows i keep thinking of things to add to it.
Also thats a great idea i should get a keg of gun powder to add next to the matches and gas haha.
That's funny you mention a receiver. That's exactly what I was going to do also.I figured I could tow the splitter right behind the box.
   / BUILT A "CARRY-ALL" FOR TRACTOR #30
I got 2"step bumper receivers (x2) and mounted one on the flat/back side of our rollover box blade, the other is going on the Kubota ballast box I'm modifying to add more fitments and adapters to allow for pulling and lifting other things.
We use the reciever mount constantly for moving our trailer, pulling a roller, and various other things.
Thomas
No matter where you go; there you are...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
Sterling 9500 (A56438)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
