burning tips
   / burning tips #21
Go to your local Fire Dept. Check to see if you need a permit. Check to see what you can burn, and how big the pile can be. Local regulations vary!
Out here, we have to get a permit. Piles are "Suppossed" to be 4'x4' or smaller. Only yard trimming may be burned; burn barrels are banned.
Our neighbor got dinged this year; he burnt construction debri along with yard trimmings, made icky smelly smoke, and got turned in...
Burning here is suspended until at least November; summer is tinder dry out here(we can not have fireworks either).
   / burning tips #22
You will need a burn permit. The permits allow you to burn starting, I think, in September and running through April-ish. In Harford County, Maryland (and possibly all of MD), there is NO burning during the warm/hot months -- all of the humidity keeps the smoke from disappating as well.
Your burn pile must be 200' from any woods and 1/4 mile away from any home. I will need to get a permit this year -- I had one a few years back. They had to come out to see my burn site to make sure I met all of the distance requirements.
You can burn small campsite type fires without a permit -- just keep some hotdogs around in case someone comes by. /forums/images/graemlins/grin.gif But if you are going to burn a large pile, get a permit.
   / burning tips #23
To JD green 227,
I don't know who told you it would be safer to burn in the winter but I would have to disagree. In the winter everything is dry and is highly flammable; fall leaves, brush, grass, you name it. In the summer time the grass is green and will help keep the fire contained. Green leaves won't catch on fire immediately and brush is thriving so it won't catch as readily in the summer either. The only tiem I ever plan a burn in the winter I actually and deliberatley plan on burning the whole field or patch of woods off becasue I know it will all go quickly. I burn the big piles that I want to keep contained in the summer because it is easier to contain at that time.
   / burning tips #24
bird Out in CA in summer everything is DEAD and dry as tinder. can't burn even a grill out there then with out getting into trouble, tossing out a lit cig a long the road will get you jail time if convicted!!! same for a few other places, here in Ohio is like you have in ILL. wet in summer good to burn time, unless you are field burning then in winter.
Mark M
   / burning tips #25
<font color="blue"> My township will only let me burn something this size during the middle of winter </font>
Is that because the ground is covered with snow and no chance for a wildfire?
I never burn mid/late winter or mid/late summer. As others stated, everything is usually dead and dry and grass fires are almost a given.
   / burning tips #26
Many good ideas have been mentioned, but one I did not see and that I use here in the wet side of Washington, in a fan. A gas powered fan set to blow at the base of the fire makes the fire burn much quicker and hotter with less smoke. If you have no access to a gas powered fan use a generator and a commercial type 'Patton' fan, mine is the 24 inch model. When I burn I get it done quick and with very little smoke as compared to others.
Do the usuals as mentioned, permit, FD okay, not when hot and dry, clear space around the fire, diesel, old oil, or a propane torch, NOT gasoline. Keep the tractor bucket full of dirt, if you are able, have a water hose nearby. Use some common sense.
steve
   / burning tips #27
I think I'll try that on my next brush fire. I use to be a sheetmetal worker and I have several old fans out of airhandlers that we took out of buildings and I have a nice generator too. Should I send pictures of the blaze when I light her up, she's about 30' long by 15' wide and 8' tall? It's all a bunch of nuisance Russian Olive trees.
   / burning tips
thanks everyone,
I don't have a big fan but my kid does play the trumpet. The hot air out of that thing will rev up any fire, bw
   / burning tips #29
It should be obvious that during mid winter in cental Michigan everything is covered with snow, which is the reason the local fire dept. will only let me burn a huge pile then. Smaller fires up to 3 feet square may be burnt any time of the year unless it is very dry, but even then a verbal permit is required from the local FD. The closest woods to my burn pile is over a quarter mile away and they will not issue a permit unless the wind speed is under 2-3 mph. If the wind exceeds that and you burn anyhow, the permit is void.
   / burning tips #30
2-3 mi/her. Wow we would never beable to burn here in ID if we waited for that type of conditon. We just start are downwind and let the fire burn back. Workd great. Last year we had a mile of windrow to burn, 4X4 feet and five lines 1000 feet long. Took two morinings to do. We burn very early to use the few % points of dew to help control the burn. It is amazing what a little mosture will do to subdue the burn rate.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2020 DRAGON ESP...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
17307 (A55853)
17307 (A55853)
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
