Bush Hog vs Woods vs.....?
   / Bush Hog vs Woods vs.....?
For a comparison:
BB72X w/ chains: $2,450
BB720X w/ chains: $3,195
   / Bush Hog vs Woods vs.....? #22
Either company makes brush cutters in light, medium, and heavy duty classifications. I've owned both brands over the years and can highly recommend either one. I am currently running a Brown 472 that is similar in specs to the BB720X and equivalent Bush Hog BH 26. I was fortunate to find a lightly used unit at 30% the cost of a new one. The durability of those units are excellent.
I like the design on the BB720X but I think it's overkill for me. Weight and price.
I'm just surprised at the $300-$350 for chains on the BB72X
Yulp, I follow Tractor Mike on Youtube. I just sold a Woods 72" finish mower. Since I do not mow the area often, the finish mower had a hard time handling the tall grass. I'd often have to make 2 passes.
2" cutting capacity and ~1000# for a 7' single spindle......neither I would consider an HD cutter. More like medium duty.
Which may be just fine.....but what do you intend to cut with it and how often? IF you are frequently mowing a pasture......either would be fine. IF you plan on mowing down land that has sat untouched for 5-6 years.....I'd want something with a little more heft.
If just doing pasture maintenance.....have you considered an 8' twin spindle cutter?
Would you consider the 72" BB72X a HD unit or jump up to the BB720X? A noticeable price increase.
   / Bush Hog vs Woods vs.....? #27
My Woods BB60 same with the metal skirt. I used it for a season, then took them off and put chains on. However, I mow on some very rough ground, as well as some trails through my woods. I was always catching the metal skirt on something and bending it or tearing it up. Since they are flexible, the chains can go all the way to the ground, providing a bit better protection for thrown objects without always catching on the ground, gouging things up, and making it hard to turn. If I were mowing in a smoother area, it probably would not have made as much of a difference.
I think I'll get chains to be safe.
I'm considering the BB720X - but I am curious what everyone thinks about the weight? i.e. when I'm mowing across a slope. Since my finish mower had 4 wheels (on my smaller tractor) it would drag the rear tires towards the pond. But now with the MX, and the chopper would have the weight on the 3 point and should help with traction, right?
What are the thoughts on the weight of the BB720X? Some people were a little concerned about at 1200+ lbs cutter on a slope.
   / Bush Hog vs Woods vs.....? #30
WHOO_EEE there rigustifson. Post #15 - lower pic - tractor on the left(LS XR 4155). Looks like you've been out raising some serious dust with that cutter. The way that tractor & cutter look - it must have been one H*LL of a dust cloud.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2023 Kubota KX057-5 Compact Excavator (A55314)
2023 Kubota...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 CAT 950K WHEEL LOADER (A55745)
2013 CAT 950K...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
