Buy Tractor And Mower or Skidsteer and Mulch Head?
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #21
For a block that size and if the rows are a 8' both ways i would buy a narrow version of these Roller Choppers and a tractor with a blade and armoured tyres or tracks and keep on truckin . After you have knocked it all down , then put a fire through it and not before as you will need the small stuff to help keep the fire going . It would be done in weeks not years .
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #22
MM I disagree, I think that my 140 will do the job much faster and cheaper than a skid steer. If you meant track type machine then I will refund your $.02 otherwise you owe me another nickel. IH I do not think that would work because of root damage to the trees. The long term goal is for those trees to be harvested for lumber and they can not afford to loose any crop trees. Pine Straw is this your plantation or are you leasing it from the timber growers?
I'm leasing the land. The stands have been pulled from their rotation and are now dedicated and exist only for pine straw production.
These are great ideas. Keep them coming please! Thanks to everyone!
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #24
My point was that they are not your trees. I bet that in 30 years or so they will be back in rotation when lumber prices go back up and they are large enough to harvest.
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #25
I think for pine straw production the area would most definitely have to be back drug.I don't think you would want to leave 12 - 24 inch material just laying.It wouldn"t bale well.
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #26
I have cut almost seventy acres of planted pines with an RC 100 and Timberax. Some was thick and some was not so bad. I averaged about one acre every 1.75 hours.
Tony
So probably any piece of equipment is going to leave large enough sized mulch material that I will have to remove it? It won't lay flat, it will be varied size chunks and pieces? My hay rake adjusts at either end by 1/16" each turn of the crank. I like to leave some sort of litter layer as a moisture barrier if I can. I always leave old straw on the floor for this reason.
We definetly don't want to even stress the trees if possible, lots of good points.
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #29
Tony
That would have to be some thin material to get that production out of a CTL
   / Buy Tractor And Mower or Skidsteer and Mulch Head? #30
Check out an FAE with trap door. You can get really fine shreds.
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
2016 Nissan Verse Note Sedan (A53117)
2016 Nissan Verse...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
