BX 2200 Axle Seal
   / BX 2200 Axle Seal #11
My BX2200 had a leak on the front axle, on the left side where it turns. Got it fixed under waranty, it was a year old, the mechanic told me if i run it in mud be sure to wash the mud off befor it dries because it can cause that seal to leak. /forums/images/graemlins/confused.gif, ive had a little leak on the front axle for almost a year, just enough to noitice it not bad, took it to the dealer and they fixed it . He said it was a oring , now its leaking again, the leak is right where the axle pivots . is that were yours is leaking.
   / BX 2200 Axle Seal #12
That's where mine was leaking. Probably a good idea to keep the mud cleaned off before it dries. I definitely think the front axle needs to be vented. I've got about 5 hours of time on mine since putting in the vent, and it remains dry.
   / BX 2200 Axle Seal #13
hey Blueicon1,
How did you vent the front axle? My BX23 is leaking a bit also. Is there a standard vent zerk I can get some where?
Thank you.
Alex
   / BX 2200 Axle Seal #14
I did end up pulling the hub off and having Kubota install a new seal. The damage was done to the seal prior to me installing the vent. To install the vent, I removed the top plug (opposite side from the dip stick), tapped a 1/4 or 1/8 NPT thread into it, installed a NPT x barbed brass fitting, some clear tubing, and a vent. Tied it about 8-10" above the axle, leaving enough slack for the axle to pivot. Haven't any pictures that show much of anything.
   / BX 2200 Axle Seal #15
<font color="blue"> ...the mechanic told me if i run it in mud be sure to wash the mud off befor it dries because it can cause that seal to leak. </font>
Is there something wrong with this picture? /forums/images/graemlins/confused.gif Buy a tractor and if you drive in some mud and don't wash it you risk oil seal failure?
Boy, I hope that is just that mechanic's opinion and not a fact! /forums/images/graemlins/crazy.gif
   / BX 2200 Axle Seal #16
Hey Bluecon1,
Thank you for the info about the vent. Henro you're right, I don't think the mud did the job, because mine started to leak in the middle of winter right after I had just finished blowing snow. I will ask my dealer to replace the seal since my BX23 still under wanrantee.
I like my dealer a lot, I think the man is a gentleman. But the only thing I don't like about him is when he takes the tractor away on the back of a pickup without strapping it down. I tried to convince him but to no avail, I guess the old saying " you can't teach an old dog a new trick" still in effect to today /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Alex
   / BX 2200 Axle Seal #17
I had both rear axle seals replaced under warranty after 100 hours on the tractor. Both sides were seaping. This is on a B2410.
   / BX 2200 Axle Seal #18
</font><font color="blue" class="small">( Hey Bluecon1,
Alex )</font>
********************************How does he get a 15 foot tractor on an 8 foot bed.??
   / BX 2200 Axle Seal #19
</font><font color="blue" class="small">( bluecon1 is talking about the front axle and the two previous posters are talking about the rear axle. Kinda like oranges and pears. /forums/images/graemlins/grin.gif
)</font>
What happened to the apples ?> LOL*
   / BX 2200 Axle Seal #20
Hey Lbrown59,
The answer is very easy, just remove the BH and the FEL you will end up no more than 6 feet /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Stop beeing such a hair splitter, or no one would want to be your friend /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Allex
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
