BX 2200 Axle Seal
   / BX 2200 Axle Seal #11
My BX2200 had a leak on the front axle, on the left side where it turns. Got it fixed under waranty, it was a year old, the mechanic told me if i run it in mud be sure to wash the mud off befor it dries because it can cause that seal to leak. /forums/images/graemlins/confused.gif, ive had a little leak on the front axle for almost a year, just enough to noitice it not bad, took it to the dealer and they fixed it . He said it was a oring , now its leaking again, the leak is right where the axle pivots . is that were yours is leaking.
   / BX 2200 Axle Seal #12
That's where mine was leaking. Probably a good idea to keep the mud cleaned off before it dries. I definitely think the front axle needs to be vented. I've got about 5 hours of time on mine since putting in the vent, and it remains dry.
   / BX 2200 Axle Seal #13
hey Blueicon1,
How did you vent the front axle? My BX23 is leaking a bit also. Is there a standard vent zerk I can get some where?
Thank you.
Alex
   / BX 2200 Axle Seal #14
I did end up pulling the hub off and having Kubota install a new seal. The damage was done to the seal prior to me installing the vent. To install the vent, I removed the top plug (opposite side from the dip stick), tapped a 1/4 or 1/8 NPT thread into it, installed a NPT x barbed brass fitting, some clear tubing, and a vent. Tied it about 8-10" above the axle, leaving enough slack for the axle to pivot. Haven't any pictures that show much of anything.
   / BX 2200 Axle Seal #15
<font color="blue"> ...the mechanic told me if i run it in mud be sure to wash the mud off befor it dries because it can cause that seal to leak. </font>
Is there something wrong with this picture? /forums/images/graemlins/confused.gif Buy a tractor and if you drive in some mud and don't wash it you risk oil seal failure?
Boy, I hope that is just that mechanic's opinion and not a fact! /forums/images/graemlins/crazy.gif
   / BX 2200 Axle Seal #16
Hey Bluecon1,
Thank you for the info about the vent. Henro you're right, I don't think the mud did the job, because mine started to leak in the middle of winter right after I had just finished blowing snow. I will ask my dealer to replace the seal since my BX23 still under wanrantee.
I like my dealer a lot, I think the man is a gentleman. But the only thing I don't like about him is when he takes the tractor away on the back of a pickup without strapping it down. I tried to convince him but to no avail, I guess the old saying " you can't teach an old dog a new trick" still in effect to today /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Alex
   / BX 2200 Axle Seal #17
I had both rear axle seals replaced under warranty after 100 hours on the tractor. Both sides were seaping. This is on a B2410.
   / BX 2200 Axle Seal #18
</font><font color="blue" class="small">( Hey Bluecon1,
Alex )</font>
********************************How does he get a 15 foot tractor on an 8 foot bed.??
   / BX 2200 Axle Seal #19
</font><font color="blue" class="small">( bluecon1 is talking about the front axle and the two previous posters are talking about the rear axle. Kinda like oranges and pears. /forums/images/graemlins/grin.gif
)</font>
What happened to the apples ?> LOL*
   / BX 2200 Axle Seal #20
Hey Lbrown59,
The answer is very easy, just remove the BH and the FEL you will end up no more than 6 feet /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Stop beeing such a hair splitter, or no one would want to be your friend /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Allex
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
