BX 2200: Replacing HST Fan
   / BX 2200: Replacing HST Fan #1
nhinze
Kubota BX 2200
All,
I've been researching these forums and the web on how difficult it is to rpelace the HST fan on a BX 2200. I have found conflicting info and only found one description specifically for the BX 2200. I'm a learn on the job newbie mechanic, so I like to know what I'm getting myself into first.
I found the description below. Is this a good/valid method? Does the shop manual help (I don't have it yet)? Any good tips?
I just replaced mine on my BX22 without removing the driveshaft, here's how.
Remove the guard plate that is under the fan. Remove the two bolts on the rear of the driveshaft by the fan. (You can use a wrench on the one of the bolts on the front of the driveshaft to keep the shaft from turning while you are taking the bolts off the rear of the driveshaft). I took off the forward/reverse pedal linkage at the rear connection which can be done using a long extension and socket just in front of the rear wheel. Then you can move the linkage toward the right side of the tractor which will give you just enough room to get the fan and adapter off. It's a good thing that fan is flexible because when you put it back on it is a tight fit and you have to bend the blades a little as you are trying to get the splined adapter and fan back on. Once you get the adapter back on, the rest is pretty easy but I did use air tools.LOL
BX2200 - broken HST Cooling Fan help Needed
Thanks,
Nick,
   / BX 2200: Replacing HST Fan #2
I replaced the HST fan on my BX2200 last month using these instructions, with a few small discrepencies.
1 - instead of removing the pedal linkage at the rear, I removed the pin holding it on the front. This allowed me to move it over enough to get the fan off and back on.
2 - it wasn't mentioned, but there is a cutout on the fan which allows you to access a bolt that holds the fan to the tranny shaft. The two bolts that the poster mentions that hold the plastic fan to a metal part are inaccessible until you remove everything from the shaft.
I did mine myself in less than 2 hours. It wasn't nearly as bad as I was expecting based on all the horror stories. To top it off the fan cost me less than $6.50.
   / BX 2200: Replacing HST Fan #3
All,
Thanks,
Nick,
This procedure was outstanding! very much appreciated. I could never have got it done with out it. The follow up post really made it clear. After reading all the post I was nearly scared away for doing the task. I am glad I was armed with your experience before I tackled it.
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
4-Wheeel Hay Rake (A56438)
4-Wheeel Hay Rake...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
