BX 23, 3 point lift speed control knob stuck
   / BX 23, 3 point lift speed control knob stuck #1
Tollster
Benton, Pennsylvania
Kubota, BX23
I wanted to adjust the speed at which I lift my mid mount and the knob is frozen. Its under the right side of the seat and the shaft goes back towards the top of the axel housing. I sprayed it with liquid wrench, but still won't budge. Any ideas? Does the MM or any controls have to be in a certain position before it'll turn. /forums/images/graemlins/confused.gif
   / BX 23, 3 point lift speed control knob stuck #2
Tollster,
I had this same problem with my BX1800 this past Fall. I hadn't adjusted it in quite some time as it was set for my mower, but when I went to adjust for my weight box it wouldn't budge. I think I tried the liquid wrench and it didn't work so I ended up sgoing out and buying PB Blaster and spraying with that and letting it soak over night. The next day it came loose.
I was afraid I was going to twist the plastic knob off so I was patient over night. I would try the PB Blaster.
Works great!
I guess I will have to adjust more often now just to keep it free. /forums/images/graemlins/blush.gif
That did the trick, I had some vovline sythetic liquid wrench, sprayed it and let it set, I had to usea set of robo grips to break it loose, as I was worried about the knob. She was very tight.
   / BX 23, 3 point lift speed control knob stuck #4
Glad to hear you got it free. It's frustrating when you go to use something and it doesn't work! /forums/images/graemlins/frown.gif
   / BX 23, 3 point lift speed control knob stuck #5
</font><font color="blue" class="small">( It's frustrating when you go to use something and it doesn't work! /forums/images/graemlins/frown.gif )</font>
If it doesn't work, then you can't use it..... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX 23, 3 point lift speed control knob stuck #6
Yup and I hate when that happens!! /forums/images/graemlins/grin.gif so does the wife /forums/images/graemlins/blush.gif
   / BX 23, 3 point lift speed control knob stuck #7
For what it is worth mine (BX2200) will not turn either. I gave up as I thought for sure I'd break the knob. Guess I will try what is suggested.
   / BX 23, 3 point lift speed control knob stuck #8
</font><font color="blueclass=small">( I wanted to adjust the speed at which I lift my mid mount and the knob is frozen. )</font>
I suppose you've figured out by now, since you have it freed up, that the knob doesn't affect the lift speed, only the drop speed. /forums/images/graemlins/smile.gif I found some PB Blaster last week, good stuff.
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
3000 Gallon Divided Fuel Tank (A50774)
3000 Gallon...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
