BX 23, 3 point lift speed control knob stuck
   / BX 23, 3 point lift speed control knob stuck #1
Tollster
Benton, Pennsylvania
Kubota, BX23
I wanted to adjust the speed at which I lift my mid mount and the knob is frozen. Its under the right side of the seat and the shaft goes back towards the top of the axel housing. I sprayed it with liquid wrench, but still won't budge. Any ideas? Does the MM or any controls have to be in a certain position before it'll turn. /forums/images/graemlins/confused.gif
   / BX 23, 3 point lift speed control knob stuck #2
Tollster,
I had this same problem with my BX1800 this past Fall. I hadn't adjusted it in quite some time as it was set for my mower, but when I went to adjust for my weight box it wouldn't budge. I think I tried the liquid wrench and it didn't work so I ended up sgoing out and buying PB Blaster and spraying with that and letting it soak over night. The next day it came loose.
I was afraid I was going to twist the plastic knob off so I was patient over night. I would try the PB Blaster.
Works great!
I guess I will have to adjust more often now just to keep it free. /forums/images/graemlins/blush.gif
That did the trick, I had some vovline sythetic liquid wrench, sprayed it and let it set, I had to usea set of robo grips to break it loose, as I was worried about the knob. She was very tight.
   / BX 23, 3 point lift speed control knob stuck #4
Glad to hear you got it free. It's frustrating when you go to use something and it doesn't work! /forums/images/graemlins/frown.gif
   / BX 23, 3 point lift speed control knob stuck #5
</font><font color="blue" class="small">( It's frustrating when you go to use something and it doesn't work! /forums/images/graemlins/frown.gif )</font>
If it doesn't work, then you can't use it..... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX 23, 3 point lift speed control knob stuck #6
Yup and I hate when that happens!! /forums/images/graemlins/grin.gif so does the wife /forums/images/graemlins/blush.gif
   / BX 23, 3 point lift speed control knob stuck #7
For what it is worth mine (BX2200) will not turn either. I gave up as I thought for sure I'd break the knob. Guess I will try what is suggested.
   / BX 23, 3 point lift speed control knob stuck #8
</font><font color="blueclass=small">( I wanted to adjust the speed at which I lift my mid mount and the knob is frozen. )</font>
I suppose you've figured out by now, since you have it freed up, that the knob doesn't affect the lift speed, only the drop speed. /forums/images/graemlins/smile.gif I found some PB Blaster last week, good stuff.
Kubota L3130 Compact Tractor (RIDE AND DRIVE) (A50774)
Kubota L3130...
Truck Tool Box (A50774)
Truck Tool Box...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
Articulated Wheel Loader (A51691)
Articulated Wheel...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Guard Rail Joints (A51692)
Guard Rail Joints...
