BX Fuse Box Question- Spares
   / BX Fuse Box Question- Spares #11
I then mounted a SPDT (center off) switch to the dash. This switch will only allow one set of lights to operate at any one time.
   / BX Fuse Box Question- Spares #12
I took the switch leads to two 12 volt, 20 amp relays that I mounted to the firewall next to the battery.
   / BX Fuse Box Question- Spares #13
I ran the wires in the 1/2" slit-convoluted sleeving from the area of the oil filter to the rear of the tractor makeing sure to miss the blades of the hydro cooling fan, coming up behind the seat.
   / BX Fuse Box Question- Spares #14
And then to the four lights mounted on the ROPS.
   / BX Fuse Box Question- Spares #15
I also made a removable mount for something called a "Go Light" that can be mounted to either the BX22 or the RTV.
That thread is in the "ATV and Utility Vehicle" forum if you want to see it.
Vince
Thanks. The hot wire is what I needed to figure out to continue. I am away, however, when I get back, I will paint my brackets, mount them and complete the wiring. I will take some pics. I love your switch. I didn't want to cut into the dash and need both fore and aft lights to work at once as wife will do most of the snow removal, so I have put the dual illuminated toggles in a waterproof box on the front of the SMV emblem behind the seat. I'll get pics as soon as it's done!
   / BX Fuse Box Question- Spares #17
Steve:
Sorry for the confusion. I am afraid that I have developed CRS Sydrome (Can't Remember S***).
At this point, I can't remember what I did yesterday, let alone last spring!
OK, I am not finished but have a couple pics. Here are the brackets I had made after a coat of Kubota gray paint. They will hold fore and aft work lights and will be cold welded to rops.
Here's my switch in a weather proof box. I saw someone else do this, so I do not take credit. I was reluctant to cut in the dash, so...
Here's a better shot of the switches. They are illumunated toggles. I will put a little electric grease in the base of them to keep water out as they are not (and should be) marine grade.
I will post the rest when I get back to it.
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
