BX Lights Upgrade
   / BX Lights Upgrade #11
Wow...that's not a tractor...it's a UFO!!
Seriously, Charlie, you'll not be wanting for light...and I do hope you have the updated alternator on your machine to handle all that wattage.
One other note: I had my aux lights and wiring mounted similar to yours and have to rethink it. Don't underestimate the ability of trees and bushes to totally destroy your handy-work. Anything that has even the smallest bit of space WILL catch on something. The garage door frame will also do a number on those light if you forget to lower the ROPs...DAMHIKT!!!
   / BX Lights Upgrade
Yea, I put in the Alternator upgrade kit this summer. Otherwise, I wouldn't recommend more than two of these lights, as they pull almost 5 amps each. The upgrade alternator puts out 40 amps, so I still have some play room left... /forums/images/graemlins/grin.gif Any suggestions???
   / BX Lights Upgrade
I used a plastic junction box from Home depot, made for weather. It had two conduit ports on it, and I hacksawed them off, one I used to feed in the wires, the other I covered with a chrome plug, which you can see in one of the pictures.
   / BX Lights Upgrade
Yup, 14/3 w/ground Romex type wire!
   / BX Lights Upgrade
Actually, the glare isn't too bad for me. I have the seat all the way back, so maybe that is why. I do get a little looking backward, but it isn't unusable by any means. I may end up buying a Canopy soon, so even that should take care of that issue.
   / BX Lights Upgrade
I've had two lights up there for a couple years now, and haven't had any damage to them. Over the years I've developed methods for each of my trees to avoid getting them hit, so I think I'll be ok, and if I do nail one of them, it won't be catastrophic...the lights were fairly cheap, I think I paid $12 each for them.
   / BX Lights Upgrade #17
Charliebrn:
Just a heads up... Keep an eye on that 14-3 wire if it runs near anything that has oil/fuel or extreme heat. It has paper on the inside which can be combustible. I know that solid copper wire can be difficult to run. If you notice the white plastic starting to discolor due to heat, I would replace the wire with automotive type wire which is heat and oil resistant. The wire is stranded is easier to route into tight areas.
I used 14-2 for my lights, but had to replace it when it started going from white to yellow/brown....
Overall, that is one good looking installation!!!
   / BX Lights Upgrade #18
Just out of curiosity, are those switches waterproof?
Also, I noticed you used rubber gromets, did you also squirt in a dab of silicone to keep out rain?
   / BX Lights Upgrade
Thanks for the heads up. I couldn't find any automotive wire that was heavy enough and had enough conductors around here, and I was in a hurry to get the job done. I have my eyes open though, and planned on replacing the battery to switches cable as soon as I find one that will work, since that is the only one around anything hot. I was careful in routing though, it doesn't hit anything that gets overly warm.
   / BX Lights Upgrade
Yup, rubber grommets and silicone. Great stuff. The switches aren't waterproof. I'm looking for waterproof lighted switches, though I need to stay on some sort of budget. I figger I've got a little more than $100 into it. I'm already getting some awful looks from the wife.... /forums/images/graemlins/crazy.gif
Zero Turn Mower (A59231)
Zero Turn Mower...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2844 (A58376)
2844 (A58376)
2011 GMC DENALI HD PICKUP TRUCK (A59575)
2011 GMC DENALI HD...
