BX or B
   / BX or B #21
I used to install new yards and did some over seeding with my tractor. I sold off most of my equipment and I only have the tractor w/fel, box blade and 6 ft tiller left. My yard is mostly level and is 1.75 ac in size. So I would use the new tractor for mowing and the loader to clear snow (when we get it). My drive way is 200 ft long with rock base. If we do get snow I have a lot of drifting problems. Thanks for all the replies. I think the BX with Fel, mmm, and 4ft tiller would fit most of my needs.
There you go.
   / BX or B #22
i just looked at the bx2670 vs the b2650; the dif is quite a bit; 3 point lift is b=1676lb; bx=680lb. the fel capacity at pin is b=1146lb; bx=745. max clearance bucket high = b84.6"; bx 71.3. wheel base b=65.6"; bx=55.1". width b= 53.7"; bx=44.5". and previously mentioned ground clearance.
the price dif was about $4000 higher for the b2650 with 60' mmm, and 534a loader.
   / BX or B #23
Hard to beat the BX price point for an all in one package...
That said... it all depends on what you plan to do with it and if you need a backhoe.
I love my BX and it has moved mountains... well... it has moved hills.
When my brother was looking he wanted a BX too... I talked him out of it because he has acreage, woods and fields and the BX tires and low ground clearance would all be shortcomings... he ended up with a L3800 and said it is just right
   / BX or B
Weil I pulled the trigger yesterday. I bought a BX 2370, fel, 60"mm and 50" tiller. Should be delivere next week some time.
   / BX or B #26
Congrats on the BX2370. Should be a great tractor for you. Please post pics when you get it.
14ft. Deer Gate (A53424)
14ft. Deer Gate...
1990 KME (A53424)
1990 KME (A53424)
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Kubota M6060 4x4 Tractor with Loader (A54865)
2018 Kubota M6060...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2017 DRAGON 150...
