BX Sold, Time For B2320
   / BX Sold, Time For B2320
Congrats on the new tractor. Nice machine.!! Best wishes with that....
I just looked at the specs and would like your thoughts on a couple questions....
The tractor is 29hp which is great.!!..But, only 21ptohp.?? This sounds a bit on the light side for a 29hp tractor. No,?? Will you use the pto>?? and if so, what attachments.??
The one other down side I noticed was the weight of the tractor...1550lbs. That sounds quite light. Will you add weights and if so, how and what.??
So many trade offs with these rigs.
JDGreenGrass - Hey there. First, I posted a photo of the B2920, but that was just a tractor, in stock, at the dealer. I will answer your questions, however, about the tractor that I am getting, the B2320, essentially the same tractor.
Remember, I am moving from a BX1860 with 13 pto hp. (think something inbetween a X700 and 2305 in Deere) The B2320 has 17 pto hp. in the hydro model. I mow my yard with a 48" RFM. It operated smoothly with the little BX, so it will be a breeze for the 2320.
Since my tasks are plowing snow, working my gardens, mowing grass and general utility, there will be no need for adding extra weight. The kilogram rating of the BX1860's FEL was 203. The rating for the B2320 is 304, or a 50% larger capacity. Since I never taxed my BX loader, the loader on the 2320 will be overkill.
JDGreenGrass's questions do lead me to review the selection process of the B2320. I did look at Deere's similar offering and liked it. I admit that the other offerings, in this size, from other colors, a.) didn't entice me and b.) the dealer networks up here is extremely spotty beyond Blue, Orange and Green.
In moving from the BX1860.​
The little BX ran the 48" RFM just fine. Pulled the middle buster in the garden just fine, (although it was disconcerting to be bottoming out the tractor all the time), had a plenty strong enough FEL for what I do, and did just fine in clearing snow and other tasks.
What the BX could not do was operate the field cultivator worth a darn. It just didn't have the clearance. It dug the potatoes, but barely. These were ground clearance issues that could not be over come.
The B2320 almost doubles the ground clearance of the BX, in the real world. In fact, Kubota's ground clearance is a class leader against the competition.
The FEL has 1/2 again the capacity of the BX1860, so that will be a major increase, although it wasn't a factor for my needs. The weight gain, for compaction of garden soil will be minimal. The 2320 is only 200lbs heavier than my little 1860. The overall length is virtually identical, which is a good thing for my needs. Width is also virtually identical.
The fuel use will likely increase, but only marginally. It don't expect it to be an issue. The D1005 engine will be 1/3 increase in displacement and horsepower, but again, I didn't require it. Never ran out of power with D722 in the BX. The higher center of gravity will make the B2320 seem slightly less stable than the BX1860, but our land is flat, so that isn't an issue.
That's the wrap up. I would simply say that the B2320 is virtually identical, in weight, width, length and shares the same engine as the BX2660. Think of the B as merely a much taller version of the BX2660, with 3 ranges and no little cooling fan and you get the idea.
   / BX Sold, Time For B2320 #33
BP, I think that you are going to be really happy going with the B2320. The points you made are well thought out, and clear, but I think you will also find other benefits that are more subtle, but make every day operation more enjoyable. I also had a BX, and consider the upgrade to my current B much more signifigant than most folks would guess by just reading specs. One thing is that you will have to look at the second set of holes in your lower 3pt arms to get that middlebuster as deep as you want it. Mine works great for digging potatoes, and tilling once I did that.
Thanks Chuck, yes, I am sure their are many things. I look forward to discovering them in real life situations, not merely as spec sheets, as you say.
   / BX Sold, Time For B2320 #35
Isn't it a third more ? :confused: ........ but I know what you
mean about using the BX as a tractor ; really is more a mower
with FEL and hitch ability .........
I'm going to drill holes in the arms to get a reduced drop for
a carry-all . My lowest hitch height is about 9 1/2" . Would
like 6"ish really.
You'll notice less wallowing-around in the ruts . I'm on 10lb
in the backs to try and get some suspension-effect
happening on my bumpy lawn sections . It's not a comfortable
ride TBH.
like 6"ish really.
ride TBH.
On specs alone, the ground clearance goes from 7" to 12". I figured my comment might be construed as somewhat imprecise, as the rear wheel on the BX is a 12" while the rear wheel on the B is 16". But, in real use, there are other design features that just give the B much more practical, useable clearance.
I will, however, disagree somewhat with the implication the BX is not really a tractor, it is. But the design centers on being a mower first. That much seems true. No tractor has a suspension type ride. That has to come from the seat alone, and I found the BX seat to be pretty good.
   / BX Sold, Time For B2320 #37
I found out several years ago after buying a BX2200 to be my life time mower that the BX's are tractors with some clearance issues but they are tractors and specifically sub compact utility tractors (SCUT). L and M owners could say the same thing about B's but they are also tractors or compact utility tractors (CUT). I've had several BX's, B's and an L and a couple of F's. The F is a Kubota mower that will do other things but it's primary function is fantastic mowing. My current BX doesn't have a mowing deck, just a FEL and BH sooooo BX's are tractors (SCUT) that are also fair mowers. Some of us have had BX's for awhile and maybe forgot our old Craftsman riding mowers but put them side by side and anyone will see they are not alike in any way other that basic shape and one of them mows only.:D
Yes, my BX was indeed my tractor. It pushed snow efficiently and powerfully. Great in tight quarters!!! It pulled my utility trailer loaded with a ton of gravel. All that was pretty good.
But when I plowed with my middle buster, one set of wheels are in the bottom of the previous furrow. Ooops! Or when I dug my potato crop, you have to straddle hilled rows. (see photo) It was in these applications that I was constantly bottoming out the BX. Here is where the ground clearance limitations were magnified and proved insurmountable. Forget cultivating taller plants.
Oh sure, all the bigger lines of tractors have even more clearance, but such machines would be highly inefficient in tight quarters and far too heavy, of course. The B simply hits the sweet spot, for my use. Insignificantly heavier, and no longer, and no wider while providing much greater ground clearance. All plusses. The Bxx20 series is indeed, still a very small tractor.
It's the Goldi-Locks phenomenon.
   / BX Sold, Time For B2320 #39
Chuck - what 2nd set of holes are you referring to? I am out of town and I cant picture them.
KJ 8'x6' Powder Coated Steel Site Fence (A50121)
KJ 8'x6' Powder...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
John Deere 6068D (A50120)
John Deere 6068D...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2015 BMW 328i Sedan (A50324)
2015 BMW 328i...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
