BX22 oil leak
   / BX22 oil leak #11
Joe,
Did you ever figure out where the leak was coming from? I have a much smaller leak coming from the same general area. Mine only seems to leak a little bit after working the tractor for a while. A week's accumulation is barely enough to wet the concrete under, no build up at all. Mine is definitely hydraulic fluid, but the leak is so slow, I haven't done much about it yet.
Kevin
   / BX22 oil leak #12
Joe, I own a BX2200, built my own FEL as well as added an additional 4 spool hydraulic valve to the rear of the tractor.... I've now got TNT. I used all the factory fittings/lines for the BX22. After installing everything I too noticed a small leak on the left rear of the tractor...just behind the wheel. That is exactly where the hydraulic block and all the lines and fittings attach. I removed the wheel and cleaned the area....as there was a thin layer of hydraulic oil all over everything. While I was there, I also checked all my fittings.....yep I found one fitting that was a little loose. I tightened it up, put the wheel back on and that was the end of the leak.
Now in your case, with only 6.5 hours on your tractor, I'd simply take it back to the dealer and let them fix the fuel indicator problem as well as the leak.
Bottom line is, it should be a simple fix and you'll be back in business. Enjoy your new tractor.......I know I've enjoyed mine. /forums/images/graemlins/smile.gif
DW
   / BX22 oil leak
Just wanted to update you on the leak. I've been waiting for the dealer to get the parts in for the faulty "sending wire" for the fuel guage then the oil leak will be fixed.
It is definitely hyd. oil. The leak has gotten 100% worse since I first noticed it. The reason: I have not used the 3 Pt. hitch for any rear implements yet until now. The slower leak was a result of the up and down of the MMM. The use of my new post hole digger had it squirting out. There was/is a loose fitting on a solid hyd. line on the inside left tire just under the fuel tank, where it looks like it joins the rear trans/upper arm lifts. There is a set screw there as well.
I cannot get it tight enough to stop it from leaking out even though it was very loose. The fitting looks as thoughit has a crush washer on it. Well that's the story for now. I'm sort of glad I know at least. I'll feel better when I get it fixed. Long winded sorry 'bout that.
Joe
   / BX22 oil leak
Sorry about the delay responses by the way.
Kevin,
The former post I wrote should give you the general area to look. Have you hooked up anything to the 3 Pt. Hitch and lift it all the way up? That's when it pours out on mine.
I'll take a couple of pictures tonight and put them up.
   / BX22 oil leak
Danny,
Thanks for the info. I think you nailed it on the head. I will be trying to fix it this weekend. I'm in the process of designing and building a deck off the back of the house. When I bought the post hole digger for the footings. {yes , I bought an Attachment before I even finish the design and plans for the deck, </font> "But honey, It'll be finished faster with this tool" } The digger really exagereated the leak-squirt-pour.
Joe
   / BX22 oil leak
This is a picture from farther out to give you an idea of the location. The next picture is closer in.
   / BX22 oil leak
Close-Up of 90 deg. fitting.
   / BX22 oil leak
Well the part finally arrived and I got the tractor fuel guage fixed and the hyd. oil leak taken care of this past week. The float in the tank seemed to be the issue with the gauge and the leak was an o-ring. I was out digging holes with it this weekend and everything seemed to work fine. That should do it for now. Thanks for all your input.
Joe
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
2014 Freightliner M2 106 24ft Box Truck (A52377)
2014 Freightliner...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
