BX22 Power loss- Possible causes?
   / BX22 Power loss- Possible causes? #11
Make sure your Tractor his fully warmed-up. My BX2200 will do the same if the transmission is not fully warmed-up. I saw this stated somewhere in the owners manual too (I believe). I usually start mine up and let it run until the temp gauge shows normal operating temp.
Dwayne
   / BX22 Power loss- Possible causes? #12
<font color="blue"> I own a bx22 and my driveway is pretty steep I have tried going up the hill in high gear and the tractor stopped. So I had to apply the break and put it in low range. The breaks don't seem too strong. it wants to roll backwards unless I really apply a lot of pressure on the break. </font>
david43a,
Last week my bx2200 was delivered on one of those tilt bed car carriers. The guy tilted the bed back, while parked on my driveway, which is sloped down.
"He says boy that's steep! you want to take it off?" I say "Rather you take it off. That way if something goes wrong, you wrecked it and I'll wait for another one... /forums/images/graemlins/smile.gif"
All the chains are off. He reaches up from the ground, puts it in neutral and starts it. It is sitting there in neutral on a REAL steep angle. Then he climbs up, puts it in gear and unlocks the parking brake and down he comes smooth as silk.
Mabye the extra weight of the backhoe and loader on your bx22 makes a difference... Just wanted to let you know how well the brakes work on my 2200 and perhaps you should have yours checked. I should think they would work pretty well with or without the extra weight...
   / BX22 Power loss- Possible causes? #13
Bill I took my back hoe and loader off and the breaks stopped well. The tractor weighs 1,500 lbs and with the back hoe and loader I think add another 1,100 lbs for a total of 2,600 lbs If you want to add my weight add atother 250 lbs for a total of 2,850 lbs. I think the breaks are ok but I will ask the dealer thanks for the Advice David.
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
2336 (A58376)
2336 (A58376)
