bx2200 air filter strap broke (again)
   / bx2200 air filter strap broke (again) #11
Tie wrap is OK but the plastic will get brittle pretty quick. My son took a piece of fire hose, about 2" wide when flat, cut a piece to length, drilled mounting holes and used fender washers and bolted it back in place. Has worked fine, gives when it needs to. That was 2 years ago and still going strong.
   / bx2200 air filter strap broke (again) #12
Assuming that the BX 2200 air filter bracket is the same as the one on my BX23... I'm on my third replacement bracket in 220 hours... My dealer has me bring him the broken parts and gives me a new one in exchange.
   / bx2200 air filter strap broke (again) #13
   / bx2200 air filter strap broke (again) #14
Right you are, when using a fixed bracket, however, cut an old canvas hose to any length needed, and it gives but holds with tenacity.
It works for me. I will attach a pic for you tomorrow.
JiggleBug
   / bx2200 air filter strap broke (again) #15
JiggleBug
   / bx2200 air filter strap broke (again) #16
</font><font color="blue" class="small">( Right you are, when using a fixed bracket, however, cut an old canvas hose to any length needed, and it gives but holds with tenacity.
JiggleBug )</font>looking forward to the picture;
thanks
   / bx2200 air filter strap broke (again) #17
thanks
   / bx2200 air filter strap broke (again) #18
I never broke the airfilter strap on my BX23, but after 120hrs I noticed the strap support brackets had broken off at the base of the bracket, closest to the engine block. I ended up with the bx22 upgrade kit. I didn't use the clamp assembly only the brackets. However I did notice the upgrade kit appeared to be the same as my original BX23 kit with the exception of a rubber strip that lined the clamp. The 23 has a foam strip that has double sided tape to keep it adheared to the stap.
I noticed at about 80 hours the backet bolts had loosened and one had completely fallen out. I used some blue locktight and retorqued. Then at 130 hours both brackets had broken off, but the bolts where still tight.
When I reassembled for the last time. Only this time I changed the torquing sequence and torque the brackets to engine block first, then snugged the brackets to clamp assembly, then tightend the clamp. I worked my way out from the block to the air filter.
I don't think this is the same issue ya'll are experiencing, but something I thought you may like to know. Its now part of my daily check and at 150 hrs...so far so good.
   / bx2200 air filter strap broke (again) #19
   / bx2200 air filter strap broke (again) #20
It broke on the BX 1500 that I was demoing, sound like a real defective part, the tractor only had eight hours.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
