bx2200 air filter strap broke (again)
   / bx2200 air filter strap broke (again) #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
I already have the redesigned part, I was wondering if there is another redesign to beef this up for if it's just going to keep breaking every 200 hours.. ?
Thanks,
- Patrick
   / bx2200 air filter strap broke (again) #2
I have broken 3 of them the last one over 100 hours ago I looked at it and don't see how it hurts anything to just let the plastic parts move around I am going to just leave mine broke. I cant see any damage to plastic housing from leaving it broke
   / bx2200 air filter strap broke (again) #3
Me to
   / bx2200 air filter strap broke (again) #4
When mine broke, I replaced it with a large plastic tie wrap. You can buy them at Home Depot, Lowes or maybe your local hardware store.
   / bx2200 air filter strap broke (again) #5
Ditto here. Mine broke last year and after hearing the price I would be paying for the replacement part that seemed to be not much of an improvement over the original I just grabbed an extra large nylon tie wrap and secured the filter, it will probably last longer than anything else.
The strap is available separately from the mount, it was only $8. About 20 minutes to install... guess I'll stock up or try the plastic-tie approach.
   / bx2200 air filter strap broke (again) #7
Don't think mine is broken yet--guess I'll add a zip tie next time I'm under the hood!
ron
   / bx2200 air filter strap broke (again) #8
My dealer made some sort of modification to the mounting point where the strap attaches to the engine in addition to installing the redesigned strap but I'm not sure what. So far so good though.
   / bx2200 air filter strap broke (again) #9
When mine broke I told my dealer when I was in there getting some new mower blades and he just handed me a new one and said they all break.
Tie wrap is a good Idea.
   / bx2200 air filter strap broke (again) #10
Tie wrap is OK but the plastic will get brittle pretty quick. My son took a piece of fire hose, about 2" wide when flat, cut a piece to length, drilled mounting holes and used fender washers and bolted it back in place. Has worked fine, gives when it needs to. That was 2 years ago and still going strong.
   / bx2200 air filter strap broke (again) #11
   / bx2200 air filter strap broke (again) #12
Assuming that the BX 2200 air filter bracket is the same as the one on my BX23... I'm on my third replacement bracket in 220 hours... My dealer has me bring him the broken parts and gives me a new one in exchange.
   / bx2200 air filter strap broke (again) #13
   / bx2200 air filter strap broke (again) #14
Right you are, when using a fixed bracket, however, cut an old canvas hose to any length needed, and it gives but holds with tenacity.
It works for me. I will attach a pic for you tomorrow.
JiggleBug
   / bx2200 air filter strap broke (again) #15
JiggleBug
   / bx2200 air filter strap broke (again) #16
</font><font color="blue" class="small">( Right you are, when using a fixed bracket, however, cut an old canvas hose to any length needed, and it gives but holds with tenacity.
JiggleBug )</font>looking forward to the picture;
thanks
   / bx2200 air filter strap broke (again) #17
thanks
   / bx2200 air filter strap broke (again) #18
I never broke the airfilter strap on my BX23, but after 120hrs I noticed the strap support brackets had broken off at the base of the bracket, closest to the engine block. I ended up with the bx22 upgrade kit. I didn't use the clamp assembly only the brackets. However I did notice the upgrade kit appeared to be the same as my original BX23 kit with the exception of a rubber strip that lined the clamp. The 23 has a foam strip that has double sided tape to keep it adheared to the stap.
I noticed at about 80 hours the backet bolts had loosened and one had completely fallen out. I used some blue locktight and retorqued. Then at 130 hours both brackets had broken off, but the bolts where still tight.
When I reassembled for the last time. Only this time I changed the torquing sequence and torque the brackets to engine block first, then snugged the brackets to clamp assembly, then tightend the clamp. I worked my way out from the block to the air filter.
I don't think this is the same issue ya'll are experiencing, but something I thought you may like to know. Its now part of my daily check and at 150 hrs...so far so good.
   / bx2200 air filter strap broke (again) #19
   / bx2200 air filter strap broke (again) #20
It broke on the BX 1500 that I was demoing, sound like a real defective part, the tractor only had eight hours.
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
