Tonight I realized something. If I mow in "turtle" (as my son calls it), the seatbelt doesn't tighten as much as when I mow in "rabbit" and is somewhat more bearable. This is unfortunate because I typically mow like a Nascar driver and therefore increase the likelihood of requiring the services of a seatbelt. I have no loader or backhoe and have installed two 50# weights on the front of the tractor to counterbalance the 3PH grass catcher. With the low profile of the BX and my lawn conditions, I can't imagine WHAT (other than the retaining wall) would tip this 1600# chunk of metal over.
I assume this this because I mow in straight paths from one end of the yard to the other and then return. My process to turn the tractor around is to turn hard left just at the edge of the lawn, then hit reverse hard while turning the wheel sharp to the right. This causes the entire front of the tractor to "slide" back around to line up with the next pass. I have even accidentally used this method on asphalt and other than having to increase my grip on the fender handle, it would have been quite impossible for the tractor to tip over. ( I ALWAYS ride with one hand on the wheel and the other on the "oh SHOOT" handle).
Obviously, with a loader (especially in the raised position) or working on a slope, the center of gravity could be great enough to tip the tractor over. I ALWAYS stop the tractor to buckle the seatbelt when working on a slope or with implements that are capable of tilting the tractor.
With that said, I would also like to include one situation where wearing the seatbelt would have been beneficial even though I was mowing on FLAT ground. I was in the middle of a long stretch of flat lawn (at full "rabbit") when all of a sudden I was thrown onto the hood of the tractor!!! I soon realized that the BLASTED ROPS had caught a LARGE tree limb. /forums/images/graemlins/shocked.gif JEEPERS!!!
Now the obvious must be stated. The seatbelt's only job isn't just to keep you from getting crushed in the event of a tipover, but also from being thrown from the tractor and consequently trampled from the same machine that had previously given you so much enjoyment . (is that a word?)
