BX2200 UDT Shortage
   / BX2200 UDT Shortage #1
FarmerFrank
Seattle, Washington
Kobota BX2200
I have a new BX2200. When it arrived I checked the Transmission Fluid level with the engine off. There was not enough in the system to reach the bottom of the Dipstick (the FEL would operate). I slowly added Kobota UDT and wound up having to put in 3/4 gal. Now the fluid registers above the "full" mark.
Questions: What kind of damage could delivering my BX so low on UDT have caused? The engine registered 1/2 hour. Should I be concerned?
Should I drain some UDT to get the level precisely between the indicators? Can too much UDT damage the transmission?
Do I have to use Kobota UDT? Are there other approved fluids?
   / BX2200 UDT Shortage #2
Frank,
I was advised that when you check the hydraulic fluid, that all the implements (FEL & 3PH, etc.) need to be "down" and "at rest". I also noticed at one point (B7500) that I had less fluid, but there weren't any leaks. Dropped the 3PH, and the fluid level was normal.
I'd probably not mix hydraulic fluid types. But I really don't "know"... /w3tcompact/icons/crazy.gif
The GlueGuy
   / BX2200 UDT Shortage #3
Yes, Frak what glueguy said is exactly true and in addition to that for the short time you used in NO--I repeat NO damage would have occurred. It seems some tractors are going out shy on UDT due to installation of the FEL which of course takes up some of the volume. Do not worry. J
   / BX2200 UDT Shortage #4
There is an apparent misprint in the BX manual. I had the same problem as you when I took delivery. Also, I had to add more UDT than called for @ the 50 hr. service to get a good level.
You should not exceed the high level indicator on your dipstick.
If you do not use Kubota Super UDT, you may a problem on any warranty issues.
   / BX2200 UDT Shortage #5
Same thing hpaapened to a lot of us BX2200 owners. Mine didn't even have the loader and it was still low. Its easy to drain a bit. I would if I were you. As for the damage potential. I would guess Trescrow is absolutly right. I would still worry (cause thats the way I am). But the worry is probably unwarranted. The 1/2 hour was probably all idle time anyway.
Rogue
Thank you for your response. I trully appreciate it.
My dealer gave me a gallon of standard UDT and reported that this is all they use, rather than the Super UDT called for in the manual. Does this sound right to you?
He also said that there is no need to lower the level. I am going to anyway. He is sending out his top mechanic to help me out with all my other little troubles.
Thanks again.
Frank
   / BX2200 UDT Shortage #7
Frank, I've talked to two different dealers and neither one even stocks the Super UDT. They only order it if a customer specifically wants it.
Bird
   / BX2200 UDT Shortage #8
Mine was also low. Took almost 2 quarts.
   / BX2200 UDT Shortage #9
My hydrostat and front differential were both low...good thing we nosey people take a look/w3tcompact/icons/smile.gif
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
1974 Ford F600 Grain Truck (A56435)
1974 Ford F600...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
