Snow BX2230 with Curtis Cab and Snow blower: Let it sno
   / BX2230 with Curtis Cab and Snow blower: Let it sno
I installed the Tiny Tach on the joystick control. It is right below the throttle and I can see it well.
I mounted the Tiny Tach with angle steel to an existing bolt on the tower. I tilted it slightly towards the driver.
The other wires you see here control my Electric chute rotator. They go to the switch box that contains a single pole double throw switch from Radio Shack.
Another look.
And another.
The cabling routes out towards the blower. Below the hydraulic quick disconnects I put a trailer harness assembly.
In the summer, I will simply unplug it and put a cap on it.
This is a shot of the Electric rotator. I used a 1994 Ford Explorer Electric door motor. Note…when disassembling it from the door, be very careful as it is under spring tension.
I purchased aluminum flat stock from Home Depot. I bent two L pieces in the vice, did a little grinding to fit it under the chute and then drilled holes to match the ones that were currently on the chute bracket and bolted it on. I then matched up two of the three holes on the motor and bolted it on. I found that an old warn out S&K 7/8 sockets fits on the spline. I then took an old 3/8 extension from my socket set cut it to fit and added it to my assembly. I drilled the hole through it and inserted the stock sheer bolt. The assembly works fantastic. The wiring took longer than fabricating this setup. All in all…a 3 hour project. Not including the running around. This is how a person with limited tooling capability gets around situations.
Different view. Note, I ground the flat stock sticking up on an angle so there were no sharp edges. The angle flows with the motor and looks better as well.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
