3-Point Hitch BX25 and 1/4 inch valve.
   / BX25 and 1/4 inch valve. #11
Here is the stops on the BX25, not sure why they are called stops because the lever doesn't get anywhere near them
Looks like they may be installed backwards as the curve "appears" to be away from the lever. As mentioned, need a picture from the top down.
Thanks guys for helping out.....no it does not look like the photo. There are no stops on the top, just what you see in the photo I posted earlier. I'll try and get a photo
   / BX25 and 1/4 inch valve. #13
Let me know if you need a picture off my 2660; believe it's the same as the BX25.
   / BX25 and 1/4 inch valve. #14
The stops on my BX2350 were oriented the same way. I never used them but if I remember correctly, I was just barely able to make the lever catch them when I pulled towards the seat. It didn't seem like they were designed properly as I really had to scrape the side of the slot in the fender to get them to work.
I felt that those tabs were only marginally useful at best. I don't have much trouble fine tuning the height without their help.
I think that a catch to hold the 3PH valve open is a better use of those mounting brackets.
Got a chance to work on the 1/4" stops. I pulled it all apart and found that I could bend the top part of the stops out and they work great now. Kubota put a brace behind the bracket which caused the actual stops to totally miss but bending out the upper part of the stop allows the 3ph lever to hit the stop made the appropriate adjustments and 1/4 inching works great.
   / BX25 and 1/4 inch valve. #16
Glad you got it. :thumbsup: Dissapointing that you had to go thru so much trouble to get it though. :(
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
