bx25jim
Bronze Member
pump running or not it will do that... once you position a cyl, then get off the spool valve, it is just the spool seal and the cyl seals to hold it...
the circuit is not being fed constant pressure from the pump.
3pt systems can use unloading and circuit regeneration to keep a sagging 3pt load lifted to near the same point, usually in a hunting or bobbing motion depending on the leak. circuit leaks, linkage signals repres of the system, then when in the correct position, circuit unloads.
that's differend from back hoe hyds and a multi circuit spool valve.
I understand what you are saying, but my point was, I could run the tractor for a few hours and not have it creep down. But let it set the same amount of time with out it running, and it would start to settle/creep. :thumbsup:
I also use the pins that are used to store the boom and keep it from swinging left to right when moving around. But the bucket itself does not have one. Thats the only one that will settle. I do however let all the pressure of my lines by moving all the levers as the book recommends. I dont have a problem with it doing what it does though unless it starts to get excessive. A good friend has a larger Kubota with a backhoe that does the exact same thing when not being used for a period of time. So no problems.....Jim
