BX25 FUSE BOX Wire Connectors ???
   / BX25 FUSE BOX Wire Connectors ??? #1
Artisan
Monrovia, California
Kubota BX25
So I see there are 3 unused holes for mini fuses in my fuse box
on my BX25.
I want to add circuits utilizing these future holes.
Can someone clue me in as to exactly what kind of connector
I need to buy (and where*) and once I have it w/ a wire attached, how do
I install it, will I simply push it in from the back till it clicks in?
Also how to remove them?
Here are links to large format pics of the front and back of the fuse box.
Maybe it is a common box ?
FRONT PIC
REAR PIC
* I went to the parts area at Kubota's website and I will be
dipped in it if I can find a part number for the fuse box and
those connector ends. I dare ya to try to find a P/N for the
fuse box! The box "might" come w/ connectors. (?)
NOTE:
OK I figured out the P/N for the fuse box. K2581-63224
It is attached to the whole darn wire harness.
NOT Good for me.
BUT! I just bought THIS on Ebay. It looks like the same company
made this box. I am gambling the terminals are the same. If so
I can play w/ it and figure things out and have some ends to
splice into my box.
   / BX25 FUSE BOX Wire Connectors ??? #3
Please let us know if it works
   / BX25 FUSE BOX Wire Connectors ??? #4
There is a tool for installing/removing the pins in the fuse box. You can get new pins and the tool at Auto Zone or other auto stores.
...and I wish I had the EXACT part number to do this.
Indeed AZ has lots of tools in this area but unless I can
ID the exact Part Numbers and or types I an dealing with
I am can not proceed.
Here is a picture of the fuse block I bought that is SIMILAR
to what I have on my BX25 davesi708. What is the AZ tool
needed to remove the pins from this fuse block and what
is the part number for the pins. ?
   / BX25 FUSE BOX Wire Connectors ??? #8
Not quite the OEM answer you are looking for, but I'm copying this guide for my auxilary fuse & relay box on my L4060. Wiring up 2 alledgedly 300 watt (more like 150-175 when I checked) LED light bars & a few other accesories. DIY Bussmann RTMR Fuse Block, Part 2 – Parts | Bodenzord
That picture above looks like the fuse box from my old L3200 as well. Never did figure out what connectors to use on that one to use the extra slots in the OEM box.
Looking at my L4060 Kubota Doesn't use Deutsch connectors or anthing from the Weatherpack family tree. The connectors actually don't look weatherproof at all for the most part. Some like ones on the hazard lights on the cab outside are just bullet connectors with soft heatshrink boots on them.
I expect to find some answers when I receive the fuse
block I bought on Ebay I referenced in post #6 but I kept
looking tonight and looks like ALL KUBOTA TRACTORS
have fuse boxes made from unobtainium. I looked at
L and M tractors, went to parts for them under ELECTRICAL
expand the tree, then around Engine#4 or so you will
see fuse boxes, all like 010 / A P/N's that all refer to
the main wiring harness. You HAVE to buy a complete
harness to get fuse boxes and terminals. One harness
was almost $1400.00
There has to be a way...I await my Ebay fuse box, hopefully
I can disassemble and ID the terminals.
   / BX25 FUSE BOX Wire Connectors ??? #10
2017 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2017 UTILITY VS2RA...
LOT: (9) Wheel Loader Shanks (A59076)
LOT: (9) Wheel...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
New/Unused AGT Industrial Quick Attach Auger with 3 Bits (A57454)
New/Unused AGT...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
