BX2750 snowblower
   / BX2750 snowblower #141
Also, it appears to have be store inside from the images, any key points I should look at if I go to look at it? Known failures? Its about 100 miles off.
It is a front mount, correct?
Will it fit in the bed of a Tacoma?
   / BX2750 snowblower #142
I have the 2750D, just the newer version. Yes front mount, about 50"-52" wide, should fit in the bed sideways. The intermediate shaft are different between Bxs. Also different pto shafts too, I think.
   / BX2750 snowblower #143
Tolister here is an old thread but good info, post 5.
Its not refering to a 2750c but need to find out which mid pto and quick hitch comes with it if any.
Looks like you need a bx2751 quick hitch and bx2752 mid pto. There is also an intermediate shaft in between the blower and mid pto. Cant remember part numbers but there is 2 sizes depending on which bx you have.
http://www.tractorbynet.com/forums/...23-kubota-snowblower-bx2750-availability.html
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
FRONTIER FAV20 LOT IDENTIFIER 65 (A53084)
FRONTIER FAV20 LOT...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
