BXpanded products
/ BXpanded products #21
Just to join in the singing of the praises, ordered and received the pallet forks and seat back bag. The mounting system is great and easy to install, great instructions included. Had it on in about 10 minutes and moved about 10 empty pallets into the barn. Great product. Wife is already planning things for me to move with them.
Great service from Harry and a great product.
Thanks again
Tom
/ BXpanded products #22
What kind of material are the pallet forks made out of that they are so light and what is their lifting capacity?
/ BXpanded products #23
Forks are steel and handle 600 lbs. We do not advocate exceeding the capacity of your loader.
/ BXpanded products #25
..Are there going to be forks available for the LA211 loader on my BX2200 any time soon.? Or do I need to keep lookin at grapples.? Your forks look like they'd be a much better match for my uses..
..I enjoyed the videos.. Thanks.!! d:^) Schneeky..
/ BXpanded products #26
Will the bag fit onto my BX2200 seatback??
If it has the holes in the back of the seat for the optional armrests it will fit. I don't think all the BX2200s had those holes. They'll have little plastic plugs.
I think the loader bucket on the BX2200 is the same as the BX23. In which case the hooks and forks will fit. Unfortunately I haven't been able to locate a loader to verify. I'll keep working on it.
/ BXpanded products #27
..Need a guinea pig.? I'd like to try it out if you have confidence in them fitting..
All I'd ask is that you refund the purchase price and cover the return shipping (28461) if they don't.. Sound fair enough.?
For what stuff I need to do they look to be the ticket.. I would be better equipped to p/u and recieve palletted stock with these as well.. A few more questions..
  1. For scooping brush in the video you use 4 forks, how well does it work with just two forks.?
  2. Can I get a single extra setup to make it 3 forks across the bucket if that'd help with brush removal.?
  3. Can the quick attach units for the forks have a chain hook on them as well as the tie-down point.?
..Thanks.!! d:^) Schneeky..
/ BXpanded products #28
Schneeky,
Send me an email to the address on the BXpanded website. We'll see if we can work out a trial.
Answers:
1) Works fine with 2 forks. Some of the smaller stuff can fall through though. Sure does look mean with 4 though.
2) 3 works very well, and yes you can get 3.
3) No, adding the hook interferes with the fork. BTW, The tie down point is for stabilizing bulky loads like trash cans, barrels, etc., not for lifting.
/ BXpanded products #29
:) Hi all,
Just want to let you know that my new BXpanded backhoe dolly arrived today. Easy to install the wheels (15 minutes). I will try using it tomorrow. Last week I wrestled getting the backhoe back on in a confined space. :mad: Afterwards, I was wishing I had ordered the dolly 1 week ealier.
Quick responses and professional communication were the norm. Also, unlike some other implements I have bought for my BX24, the documentation was actually written well and easy to understand (not that the dolly needs alot of instruction). My brush mower basically had one line of instruction info "Do not use this equipment unless you know how to do so" :rolleyes: Not very comforting for a newbie like me. I appreciate that the folks at BXpanded took some time to write up step by step info.
BTW, if you have not seen the videos on the BXpanded website you should check them out. Very informative and helpful.
Bucket hooks will be my next purchase soon.
Keep up the good work!
Sam
/ BXpanded products #30
Wow! That's awesome! I can feel the checkbook getting lighter already. ;)
With reference to Schneeky's #3 question; From the install video of the forks, could you not pull the pin, and leave the fork off in order to have a chain hook on it? That would leave a gap where the chain hook wouldn't interfere with the installation of the clamp on unit.
Also, I have a tooth bar on my bucket, do you foresee any issues with that other than positioning the bars to fit in between the teeth?
/ BXpanded products #31
The toothbar shouldn't create any problem other than as you mentioned, the forks would have to be positioned between the teeth. As for Schneeky's question; mounting the hook on the fork bracket creates an interference with the top of the fork itself. The hook can't be moved rearward to eliminate that problem without interfering with the quick attachment mechanism.
BTW, We just completed the dolly for the Front Loader. We hope to have pics on the website by tomorrow. It also works with toothbars installed.
Harry
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63118)
2023 Kubota...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
PALLET OF MISC COMPONENTS (A63745)
PALLET OF MISC...
