Bxpanded Quick On Pallet/Brash Forks
   / Bxpanded Quick On Pallet/Brash Forks #11
You will like them. I have carried 2 railroad ties at a time with them. The lift wont do it but the curl will just enough to get them off the ground. I have never maxed out my hydraulics with the bucket full, but do it every time i use the forks.
I welded 1 chain link on the bottom of each one. This way, I put a tie down around the back to keep them from slapping.
The w pins are a pain, but if you get the instructions on how to tune them up, that's all you need.
I'm not real impressed with these forks. 1-you cant see them when you're trying to get under something. 2-They may be great for moving a couple heavy things once or twice and repetitive use for light weight limbs and such. For repetitive use moving heavy things they are not very good. 3-The retaining pins are crap. The material that the retainers are made of needs to be harder or something. I have to re-tweak them after every third or fourth load of logs and its a 'pita'.
I understand now why those that have them are going to something different.
Its a clever design and probably has its niche but they aren't for heavy continual use moving lots of heavy things. You will be rebending those dadburn retainers.
   / Bxpanded Quick On Pallet/Brash Forks #13
I use mine a lot for heavy stuff. I think as the bucket lip and the retainers flex you have to adjust. Mine stopped needing adjustment after I used them alot. I did get frustrated with the pins. I have lost 2, but bxpanded has sent new ones when I asked.
   / Bxpanded Quick On Pallet/Brash Forks #14
The only reason I don't make some little brackets to bolt on is I like being able to adjust the width.
I'm stuck with them now. I will have to figure something out.
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
1990 35 Ton Phelan Low Boy (A57453)
1990 35 Ton Phelan...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
(2) 55 GALLON DRUMS OF WINDSHIELD WASHER FLUID (A58376)
(2) 55 GALLON...
2007 Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
2007 Sterling T/A...
