Bxpanded Quick On Pallet/Brash Forks
   / Bxpanded Quick On Pallet/Brash Forks #11
You will like them. I have carried 2 railroad ties at a time with them. The lift wont do it but the curl will just enough to get them off the ground. I have never maxed out my hydraulics with the bucket full, but do it every time i use the forks.
I welded 1 chain link on the bottom of each one. This way, I put a tie down around the back to keep them from slapping.
The w pins are a pain, but if you get the instructions on how to tune them up, that's all you need.
I'm not real impressed with these forks. 1-you cant see them when you're trying to get under something. 2-They may be great for moving a couple heavy things once or twice and repetitive use for light weight limbs and such. For repetitive use moving heavy things they are not very good. 3-The retaining pins are crap. The material that the retainers are made of needs to be harder or something. I have to re-tweak them after every third or fourth load of logs and its a 'pita'.
I understand now why those that have them are going to something different.
Its a clever design and probably has its niche but they aren't for heavy continual use moving lots of heavy things. You will be rebending those dadburn retainers.
   / Bxpanded Quick On Pallet/Brash Forks #13
I use mine a lot for heavy stuff. I think as the bucket lip and the retainers flex you have to adjust. Mine stopped needing adjustment after I used them alot. I did get frustrated with the pins. I have lost 2, but bxpanded has sent new ones when I asked.
   / Bxpanded Quick On Pallet/Brash Forks #14
The only reason I don't make some little brackets to bolt on is I like being able to adjust the width.
I'm stuck with them now. I will have to figure something out.
2016 BOBCAT T650 SKID STEER (A52709)
2016 BOBCAT T650...
2019 TAKEUCHI TL8 SKID STEER (A52709)
2019 TAKEUCHI TL8...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56436)
Greenworks...
John Deere 1025R (A53317)
John Deere 1025R...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
