Cab Owners - How well does your A/C work?
   / Cab Owners - How well does your A/C work? #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
For those of you who have a cab on your tractor, how well does your air conditioner work? Please say which make/model you own.
I'm close to buying a cab tractor, and I've tried a few that seem to have weak air conditioning. These have been new tractors, not used ones.
It makes me wonder whether the a/c will keep up in real world conditions in the hot Texas summers we have. I understand that if it's 110 degrees outside, the a/c isn't going to keep it 65 degrees in the cab. But a couple I tried made me doubt whether they would keep up if it was 95 degrees outside, and that would be a real problem.
I grew up on a farm and worked on the farm all year after school and all day every day during the summer. One summer I worked for another farmer who had a cab tractor, but the a/c didn't work. NOTHING is more miserable than a cab with no a/c.
   / Cab Owners - How well does your A/C work? #2
MF 1635 , 540 hours, still nice and cool in the cab!!
We get murdered with humidity up here, so the AC gets a work out!!
   / Cab Owners - How well does your A/C work? #3
I have a Mahindra 5010HST Cab our weather here in Arizona is hot as you get over there in Texas. The A/C works good a big help will be to get the windows tinted if you go with a Cab model. Good luck. :thumbsup:
   / Cab Owners - How well does your A/C work? #4
B3030HSDC. It'll freeze you out.
   / Cab Owners - How well does your A/C work? #5
JD 3720 works great just keep the filter clean.
   / Cab Owners - How well does your A/C work? #6
MF 1600 series. A/C on max blowing on your head will give you a brain freeze.
Been in the cab with 33°c outside temp and be freezing in the cab.
   / Cab Owners - How well does your A/C work? #7
L5740 works like a charm so far.
   / Cab Owners - How well does your A/C work? #8
B3030 HSDCC bought new in 2007. Approx. 685 hours on it. It can be over 90 degrees F out and I have the AC on medium. No need to put it on high or it gets too cold for me. And in the winter the heat works just as well too.
   / Cab Owners - How well does your A/C work? #9
If not for the AC in our L5740 and M8540, I couldn't use a tractor, keeps me comfortable, but you have to keep the filters clean.:eek:
   / Cab Owners - How well does your A/C work? #10
Kubota L3540. So far this summer no problems. Stays cool and don't have to put it on high. I try to park it in the shade so its not so hot before I start. Those glass windows are like a greenhouse without a/c.
   / Cab Owners - How well does your A/C work? #11
2006 L3430HSTC. While NY is nowhere near as hot as Texas, I've been in it on some really hot days and never wanted it colder.
   / Cab Owners - How well does your A/C work? #12
My LS keeps it plenty cool or warm as needed. My brother in laws New Holland burned up the compressor within 6 months of new which was warranted and last month he had to put in more Freon but no leaks were found. His tractor is about 4 year old and with Freon topped up, it will freeze you out.
   / Cab Owners - How well does your A/C work? #13
I ran an Allis Chalmers 8050 yesterday bush hogging for about 4 hours in 90 degree heat...
Cool as a cucumber...
30 year old tractor with 4500 hours and she works real good...
Most modern tractors today have ample cooling capacity in the radiator and AC condenser to keep you comfortable even in the hottest weather...
The air ducts are blowing the cold air directly on your head...
A cool head equals a cool body...
I do second the tinting suggestion...
Once you get a cab you will not go back...
Honest...
   / Cab Owners - How well does your A/C work? #14
Had the same tractor. Same result with the A/C.
Although my skid steer has A/C, I have yet to use it because I have the cab door out of it all summer. I generally don't need to be in it for long enough periods of time to need the air conditioner. Winter is a little different. I can pretty much blow snow all day in a T shirt because the heater works so well.
   / Cab Owners - How well does your A/C work? #15
GL4060 bought new this spring. TN weather ain't pleasant this time of year. So far I haven't had it higher than 2 on the fan speed dial.
   / Cab Owners - How well does your A/C work? #16
I have a L3940 with 550 hrs and it keeps you really comfortable even when it above 90. I've had no problems with it at all.
   / Cab Owners - How well does your A/C work? #17
Mine works well for sure;need to turn it on when it hits 65 degrees due to all the glass.
   / Cab Owners - How well does your A/C work? #18
5340 cab will keep cool on 90 plus day no problem almost to cold
Thanks for all the responses, folks. Sounds like those Kubota a/c units are sized appropriately to do the job.
I should have posted this in the general forum since I'm considering other brands too (although I'm lusting after the L4740 the most).
   / Cab Owners - How well does your A/C work? #20
I used an old 1066 a couple of summers and you could throw a cat through the cracks in the cab and that thing would freeze me out. This summer I baled straw with a JD 6320 and at mid '80 it got hot in there, the next day, I blew out the screens and the condenser and it was better, but just barely comfortable. I think the new freon is not nearly as good as the old R12, however my cars with the new stuff works really well.
Sakai SW354 (A60462)
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
KBH 25T Tender (A56438)
KBH 25T Tender...
