I have an early Mott 48 utility mower. It has 60 stations of 4.7" blades mounted on 5/16" pins. (386 blades). I understand that it is designed as a "fine cut", by I would like to use it to keep a recently cleared brushy area knocked down. The maximum anticipated brushy material will be about 1/2" diameter 3' tall.
I would like to convert it to a ring or shackle mount blade with some more mass to help power through the material.
Would it make sense to go down to 30 stations of bigger knives?
Can you offer any ideas of the parts I could use to accomplish a "coarse cut"?
Good evening xskier,
Your Mott finish mower is a a monster mower when it comes to brush believe it or not as the finish rotors
will knock everything down to the sod to get rid of the invasives for you.
If you want a rough cut simply raise the cutting height and it will do that nicely as well.
There is no need to change the mounting for the grass slicers and reduce the number of knive stations as you
will in essence reduce the throw wieght of the knives by changing the long grass slicers for different knives and
thats a no win for you or the Mott as the rotor was designed for the grass slicers and dethatching blades.
The other 500 pound canary saying Here kitty, kitty, is that you will lose a lot of suction created by the aerodynamic
lift that is created by each grass slicer to cut everything and thats a lose, lose, NO NO NO NO!!!
You will be fine with flail mower the way it is really and all you need to do is sharpen the grass slicers or spring for
new ones from one of the venders we always mention of which there are 3 at least that sell flail knives and dethatching blades.
Just drive slowly when mowing until you have ther finish you want as the flailmower will work best when the rear roller is
touching the turf because of the aerodynamics(massive suction) created by the grass slicers and the mower hood.
No worries, no need to change anything, just raise the cutting hieght and spring for new grass slicers, as you should always
have spares anyway.
The kinves you have may simply need a bit of light dressing on a bench grinder-be carefull of the cutting edges as you can
foul them if the edge is not straight.
I have a Wen wet well grinder for table and carving knives that I use for or Lawn Genie knives and it is really slick as it cools
the grass slicer as it grinds the edges.
Welcome to the flail mower nation.
"Once you go flail you never go back"
