5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,993
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
5030
I am a little confused on your question??? Or answer???? The 175 p.s.i is what the compressor shuts off at, not the amount of pressure that would be getting to the plasma cutter. That is what your regulator is for but I'm sure you understand that already. Also in your cutter it has a feature that will make it shut off if it gets to much pressure. Also your are correct in one respect that it is all about the cfm, and not tank size I have to go over that on a daily bases so you are preaching to the choir.on the other hand this particular gentleman does not have a compressor that puts out 30cfm a more realistic number for him is probably in the neighborhood of 12 to 18 depending on what formula you use. So in order to make the most of the compressor that he has it is beneficial to run it at a little higher p.s.i to try and make it perform a smite better. So there the info do with it what you may. Nic :thumbsup:
175 PSI is sort of the industrial standard for receiver/supply line pressure. The pressure to the cutter is regulated prior to, however, if the receiver pressure is 175, then the supply pressure is 175 and the delivered CFM is limited to the piping diameter or what it will flow at a given PSI. In my case, all my hard lines are 1" in diameter.
What I'm saying is, the lower the pressure the compressor runs at, the longer it last, less heat is produced and it's overall a better scenario.
If the compressor is marginal in CFM delivery, it's a simple matter to add additional receiver capacity with an in line receiver between the point of compression and the use end. That's done all the time in insudtrial settings. I just happen to have adequate receiver capacity, around 175 gallons total.
The more receiver capacity, the less the compressor cycles, no matter what the pressure is set at because there is more CFM of compressed air available. Additional receivers also are a great way to dry down the air. They let it cool down and release the excess moisture prior to the point of usage.
Especially plasma is susecptible to moisture laden compressed air. Plasma needs dry, oil free air for the longest consumable life, especially in mechanized cutting situations. I run a refrigerated dryer off the supply line plus a Motorguard 1 micron cartridge filter in front of the air inlet for the HT.
Additional receivers are so easy to plumb in. A couple isolators (inlet and outlet) and a drain cock and you are good to go.
