Thanks for the suggestion, Gary, but the object I'm searching for is rather long and narrow. If you envision the type of funnel you'd use to put ATF in a car, it's the lower half of a two-piece unit. The upper end of it was just narrow enough to go down through the filler neck (a misjudgement on my part). I figure it's laying on the bottom of the tank, and if I can get a wire hanger with a small hook on the end to go through it, the hook will catch and I can then pull it back up through the filler, or if I don't have luck there, through the larger hole on the top if I take the fuel gauge sending unit out.As I reported in my reply, look around your house for some plant stakes, those little pieces of bamboo about 3/8" in diameter or if you have some on your property, just cut you a couple of small pieces. A small wooden dowel rod would work also and either of them is stiffer than a coat hanger wire
