Can rear ballast be dangerous?
   / Can rear ballast be dangerous? #21
First, I really appreciate all the advice. Thank you all. I guess the question now is how much ballast to have. I have researched this without clear answers but what I learned is that some is better than having none, the owners manuals no longer give that info for many manufacturers of tractors, and some people say to use a weight equal to your maximum front loader capacity.
I guess I could get heavier weights for the 3PH bracket, but lifting these weights is getting hard. Isn't the tractor supposed to keep me from manual work? The forks on my new pallet fork practically killed me. Before I ordered it, I read the reviews and people said the forks are removable, but "kind of heavy". REALLY??? 85 pounds each is more than I care to move around manually these days.
My slopes are probably gradual by most standards. My yard is poorly landscaped and there are lots of dips and rises, that all add a little "thrill" to the tractor ride. Maybe 40 degrees for about 30 feet is as severe as it gets. I did learn the 4WD rule for going down hills the hard way. Luckily I stayed pointed in the right direction, and upright. Just a little older (and maybe wiser).
@oosik: There must be some good fishing in those waters?
@Thomas: Yep. Lebanon. Actually I'm in Etna, but nobody has ever heard of that unless they are local. It's been a tricky adjustment as I always lived near the ocean. Been here 16 years and still really miss the ocean.
you don't need to be lifting any weights to put on the 3pt. Just buy or build a ballast box or ballast barrel and hook it up like any other 3pt implement. You can use a 55 gallon or smaller in your case barrel. You can use the top unused space for storage of other things. I use the top of mine for storage of log-chains. Shoot for about 500-600 lbs for you tractor. You can build your ballast box for certainly less than $100. Start with buying a drawbar at tractor supply and integrate that into your plan, filling the box with concrete or junk iron if you want than concrete over the top. Include some 2 inch PVC tubes upright to hold handle tools, Many will include a 2 inch square receiver hitch on the back integrated and tied into your drawbar inside your concrete mix. The end result is you have a nice rear weight, with the utility of storage on top and handle tool storage and a hitch receiver if you need to install a ball. Put some hooks on the outside so you can hang a couple of 5 gallon buckets on the outside. If you cut a lot of wood, you might want to incorporate a plastic scabbard for a chainsaw too. Use your imagination and/or do a search for ballast boxes and you will find hundreds of them with pictures on this site. Think it thru, look at what others have done, make a plan, and stop lifting and taking off and on weights.
   / Can rear ballast be dangerous? #22
The correct answer is ... maybe. It's all about the incline. When I mow my steepest hill, I don't want any extra weight behind me. I keep the loader on and keep it as low and forward as possible. Even then, I get concerned about the front getting light. Your slope may not be as steep as mine though. I have all four tires loaded to keep as much weight on the ground as I can. The loading doesn't add a lot of weight to the small fronts, but every little bit helps .
^This.
Physics says (do people even believe in science anymore?) that weight behind the axle makes front end lighter, so does an incline. Also note that rear weight gives rear tires more traction to dig in and rotate (flip) tractor around rear axle instead of spin. Tires and soil conditions make a difference too.
Using 4wd and watching when front tires get “loose” is one indicator.
   / Can rear ballast be dangerous? #23
Deepdrop.
"@Thomas: Yep. Lebanon. Actually I'm in Etna, but nobody has ever heard of that unless they are local. It's been a tricky adjustment as I always lived near the ocean. Been here 16 years and still really miss the ocean.
I grow up in Etna now live on Blueberry Hill Lebanon.
If you live on the Steven Road old joke is all animals legs are shorter on one side than side because of terrain...one thing for sure area you live in you'll always have good crops of rocks.
   / Can rear ballast be dangerous? #25
Have a SCUT, and its a "lightweight".... IF going to do heavy FEL work yes the 500-600 lb. ballast goes on QH..... IF no real FEL work ballast is off, did notice one time on awkward side hill turn (I know bad thing) front steering was a little "light" with empty FEL and ballast on..... ITs pretty much a judgement call on what work you are doing with FEL or just need more traction to drag something... At least in my mind (but that is a confusing place) .... Never subscribed to the loaded tire theory. but may suggest it...
The two pic below is why I decided to make ballast box, and it was fabricated by only materials I had in scrap bin pulse about 9 bags of sackcrete......
By the way "runs like a dead deer" weighs in at 520 pounds by JD manual....
Dale
   / Can rear ballast be dangerous? #26
This is what my manual says for my SCUT.... Might be a formula to go by if you can work with your numbers....
Dale
I've been searching the forums and it seems there are quite a few discussions about determining proper ballast, and they never seem to find an answer. I guess I'll keep reading and learning, but I do need more weight than I have.
I think my original question is answered, that if I'm going up a steep hill with no weight on the loader, the rear weights might put me at risk for backwards rollover. I would take them off in that situation. Otherwise, I'll leave them on all the time.
Thanks again to everybody for helping a new tractor owner.
   / Can rear ballast be dangerous? #28
I’ve got a hook on the back of my box blade. Sometimes if I’m pulling something too heavy especially with a downward angle on the chain it will lift the front wheels up. But a backflip can’t happen. The front wheels can lift maybe 2’ before the blade hits the ground. Your tractor is just a tad smaller than my L3800. I find loaded tires and my box blade that’s probably 500 pounds a little lacking for ballast but it’s enough to get by. I bushhog all the time without a loader in. Even without the loaded for front weight the front end still has enough weight on it.
   / Can rear ballast be dangerous? #29
Dale
Some of you might be wondering how he is able to pick up that JD lawn mower without it falling out of the bucket. I suspect since that JD has a steel tube front "bumper" that just so happens to fit and wedge under the upper lip of the bucket on the little Massey, that this allows the JD to stay "stuck in the bucket" as he raises it off of the ground. The poster can confirm or deny this, but it makes for a neat photo. :)
   / Can rear ballast be dangerous? #30
My Op Manual - RE: rear ballast. Paraphrasing here - "Be sure to use adequate rear ballast when lifting loads with the FEL".
JMHO - LITIGATION is the reason there are no definite recommendations or formulas in the Op Manual.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
