Can someone explain how the CP302 Miller MIG Power source controls Amperage?
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #1
Ehanson
Kamloops, B.C.
S373-D
Like probably most MIG Power sources, I am wondering how the user chooses the welding amperage?
I see a single control on the CP302 Miller for voltage control, I have a Miller Xtreme 12VS wire feeder,
which has a control for wire speed, but I don't
understand how you choose the amperage? ( if you were running the CP302)
Is amperage requirement done automatically through the voltage setting?
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #2
Wire welding if a constant voltage process, the amperage is dependent on voltage and wire feed speed
Yes, OK , I figured it must be something in the unit, (a circuit board, processor?) that can ramp up or down the amperage.
Kind of baffles me how, with different wire sizes, but must be able to do it somehow.
I know the Miller Xtreme 12VS has a switch for CV (constant voltage) & CA (constant amperage).
I thought MIGs would have three settings, voltage, amperage & wire speed.
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #6
I'm NOT familiar with either unit.
Use the weld calculator from Miller. Set voltage on the power source. The wire speed (IPM) setting on your suitcase feeder will set your. amperage.......I think:)
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #7
When running a CV Mig welder the wire speed controls the amperage. And there is a knob for the voltage.
Ok, I think I get it, thankyou everyone!
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2020 DRAGON ESP...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
