Can someone explain how the CP302 Miller MIG Power source controls Amperage?
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #1
Ehanson
Kamloops, B.C.
S373-D
Like probably most MIG Power sources, I am wondering how the user chooses the welding amperage?
I see a single control on the CP302 Miller for voltage control, I have a Miller Xtreme 12VS wire feeder,
which has a control for wire speed, but I don't
understand how you choose the amperage? ( if you were running the CP302)
Is amperage requirement done automatically through the voltage setting?
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #2
Wire welding if a constant voltage process, the amperage is dependent on voltage and wire feed speed
Yes, OK , I figured it must be something in the unit, (a circuit board, processor?) that can ramp up or down the amperage.
Kind of baffles me how, with different wire sizes, but must be able to do it somehow.
I know the Miller Xtreme 12VS has a switch for CV (constant voltage) & CA (constant amperage).
I thought MIGs would have three settings, voltage, amperage & wire speed.
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #6
I'm NOT familiar with either unit.
Use the weld calculator from Miller. Set voltage on the power source. The wire speed (IPM) setting on your suitcase feeder will set your. amperage.......I think:)
   / Can someone explain how the CP302 Miller MIG Power source controls Amperage? #7
When running a CV Mig welder the wire speed controls the amperage. And there is a knob for the voltage.
Ok, I think I get it, thankyou everyone!
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
