Can The Regen Circuit Be Beat
   / Can The Regen Circuit Be Beat #11
Odd ball thinking just to beat the regen circuit... could you limit the flow using IN-LINE FLOW CONTROL on each end? Granted it would be slow, closing one valve and open another... but would it work? (~$50)
That won't work since is doesn't limit the pressure, just the flow.
   / Can The Regen Circuit Be Beat #12
The simple reason that a regeneration circuit will not work with 2 single action (SA) cylinders is because equal pressure is put on each cylinder during the extend/dump, thereby canceling out any movement. So is there a way using different size/length hydraulic hoses, between the spool and cylinders, to change the pressure once it got to the cylinder? Or by having different size cylinders on each side, one side twice the size of the other? This would allow one SA cylinder to overpower the other.
Is there a mechanical engineer out there that can answer this question? Or is my solution just wishful thinking?
A URL some may find informative. http://www.hwhcorp.com/ml37939.pdf
Sorry, but I can't figure exact what your question is....What, in detail, is it you want to accomplish?? Aren't your two SA FEL cylinders acting synchronized??
You always need a single rod, DA cylinder to be able to utilize a regen circuit. It have to be a volume difference between the two sides of the piston. If there are two cylinders, like on a FEL lift, they need to be plumbed strictly parallel. Regen-eration of flow, means that both sides of piston get pressurized, and the force differential makes the piston to extend. Speed and force will be identical to cylinder with no piston connected to the rod.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2016 John Deer 5075E (A60462)
2016 John Deer...
2019 CATERPILLAR 320 GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
