Can you blend synthetic and "real" oil
   / Can you blend synthetic and "real" oil #41
our 05 int dump truck came with syn all around.. gear case and all. ;) that count?
Don't know, my 2010 lubricant cross reference guide makes no mention of synthetic oil being factory fill. It also references 4 diesel engines used; Caterpillar, Cummins, Detroit Diesel & International.
   / Can you blend synthetic and "real" oil #42
i can tell you there were labels on the oil fil s all stating to use synthetic oil only !
first time i had ever seen that.
i'd have to find out engine type.. thinking international.
   / Can you blend synthetic and "real" oil #43
Some of the vehicles that come with synthetic from the factory do so because it is the only way they can keep them from breaking down due to the extremely high underhood temps. The Corvette, for one. Some are using synthetic from the factory to lower the friction so they can make their published fuel efficiency numbers.
Reading between the lines, I gather now that more and more engine cylinder walls are honed with plateau finishes, the need for a true breakin period is less, so putting in synthetic at the factory fill is more common.
   / Can you blend synthetic and "real" oil #44
Yeah, the old "break it in on dino to seat rings,bearings,etc" is an old wives tale. Many new and very expensive vehicles come from the builders with synthetic oil
If the engine is properly built then synthetic can be used. There are engines that do require a break in oil that lets metal to metal contact occur to seat rings.
I put synthetic in a new car and it took 75,000 miles before it quit burning oil.
   / Can you blend synthetic and "real" oil #45
Curious, what kind of truck came with synthetic oil?
My 2008 Nissan Titan came with 5W30 Valvoline Syntech from the factory.
Nissan started synthetic in 2003
Chris
   / Can you blend synthetic and "real" oil #46
Harley puts syn oil in their high performance factory CVO engines but dino in the rest fwtw. I switched to syn oil in mine and I now use a qt between changes. Fact it may be tapering off as of the last change but it is not a huge deal it may quit may not time will tell. Air cooled engines have varying clearances and temp swings is my reasoning on the phenomenon.
Honda hybrids all come out with Mobil-1 0-20w is one car I deal with that is syn only and I believe Toyota is using the 0-20 syn in cars for sure. I haven't seen that new of a truck yet to know as of I am pretty sure 2012 a least if not earlier.
   / Can you blend synthetic and "real" oil #47
My 2011 JD5075M came from the factory with synthetic break-in oil. Deere specifically states in the Owner's manual to NOT change out the oil until 300 hours on the engine. After the break-in period - you can use whatever oil you want - as long as it meets or exceeds the SJ specs.
I'll probably stick with synthetic...
AKfish
   / Can you blend synthetic and "real" oil #48
AKfish, my manual on my 5075M has the word "maximum" on the 300 hour first oil change and the dealer suggested I change it at 50hrs (although the dealer has a vested interest).
   / Can you blend synthetic and "real" oil #49
I find no reference that says Mobil 1 is used in Ford Trucks, please state year make and model.
My father in law works at the Brook Park plant and Mobil is their supplier. Ford F250 2001
   / Can you blend synthetic and "real" oil #50
Wow, everybody has a different opinion. My dealer has encouraged me to at least double the recomended 50 hour first oil change on all three of the CUTs I have purchased. He says that a lot of people don't actually work the engine enough to do the breakin correctly, so he asks that we double the time. Driving it around, using the loader, even mowing lawn does not tax the engine, he claims. In my opinon, some heavy PTO use (like a large brush chipper) would be nice, or hook it to a field disk or digger and pull as hard and as fast as you can for an hour or two (again, my opinion). You get one chance to do it right.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
1262 (A50490)
1262 (A50490)
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
1827 (A51248)
1827 (A51248)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
