Can you buy too heavy of a rotary cutter?
   / Can you buy too heavy of a rotary cutter? #31
Too bad you weren't up around here. I got a guy trying to sell me an mx5 in real good shape for $400
   / Can you buy too heavy of a rotary cutter? #32
Yes, semantics. I could careless what fictitious or marketing lingo a mfg tries to use to classify something. Like light, medium, heavy duty. Extreme, regular, premium, , homeowner, professional, commercial, industrial, etc.
When I said it was a light duty cutter, that wasn't meant as a reference to the mfgs meaningless classification. It was meant literally. A sub-600 pound 5' cutter, is indeed LIGHT duty
And when I replied it was meant to try and provide some standard means of actually comparing cutters. Just go out on Craigslist and see everyone claiming "Heavy Duty" to see that it's anything but.
Thanks for the correction on the Landpride classifications. I was mixing up the 1860 that I picked up for my B7800 with the "Medium Duty" 6' units I was comparing for my Kioti.
I don't believe that the manufacturer's labeling is meaningless. The basic basis of classification is gearbox HP and decking thickness.
I agree that weight is a factor in determining the duty level of a cutter, but it's usually a "byproduct" of the decking thickness. Or, rather, they can be seen as interchangeable metrics.
Didn't mean to agitate you. It's just that all of this was extremely confusing to me until I did a bunch of research: seems folks everywhere make claims about things being "heavy duty" but there usually isn't anything to support those claims.
"Medium Duty" cutters don't pop up around here. The 286 that I picked up is about as close as I could get: and the PO welded 1/4" plate steel on the decking, to that makes it almost a "Medium Duty" cutter. New 6' cutters run around $3,500. which wasn't really going to happen for me.
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
