leveled
- Joined
- Apr 12, 2008
- Messages
- 255
- Location
- NY
- Tractor
- MX5100HST FEL, KX121 MINI X GEHL 6640 Ferris IS3200z Kubota 1100RTV
I have a issue with my car lift. It will not raise or start up, with a load on the it. I have checked voltage 220 plus... and the capacitors on the electric motor . I had no power at the start capacitor on start up, so I assumed the contacts going to the start switch or the centrifugal switch were bad. I took the motor in for service and they told me the internal switch was bad. I had them repair it for about 115 bucks.
I have now reinstalled the motor on the pump and still have the same problem, I check voltage again and it seems to be correct, I even bypassed the electromagnetic switch by using the breaker as a temporary switch. The lift will operate if is lowered completely to the ground or if i use the lowering handle as a temporary pressure buffer.
I am at a stand still waiting on a service tech for the manufacture of the 4 post lift, I feel it may be a restriction in the pump of some sort. I have already followed up with the electric motor shop and they have said it must be on my end.
Anyone have a idea what it could be?
Thank you
Thank you
