ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,724
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
OK, The Bendpak website lists 1.5 and 2.5 HP motors for 4 post lifts.
a 1.5 motor would have a FLA of 7 amps more or less.
a 2.5 motor would have a FLA of 12 amps more or less, but the 12 amps would be correct for a maximum loaded lift. Empty, the lift should draw considerably less!
It looks like the motor has to work its maximum capacity to lift an empty platform.
I would suggest that you lift the platform to 5 feet, make sure the platform is safety locked, take the hydraulic hose of the cylinder and put the hose in a container. Than start the pump and check if there is full flow. The motor/pump should run very easy.
If you have a full steady flow, than that would narrow the problem down to the cylinder or mechanical.
Good stuff Bert.
